Vijay_kumar74
In order to try to understand subjective perceptions to objective data, need to understand some fundamentals of audio engineering. E.g. what is mic level output, what is line level output. How does audio signal in DB get converted into analog voltage and current values? E.g. if mic is recording about 60 DB audio, and there is sudden 120 DB loud blast sound, then who limits/clips the audio, if at all, and at what value?
Effectively, between what DB values does audio get limited after mic recordings? How do these analog audio get converted into voltage and current values? How are their voltage and current values determined and get limited? What does PreAmp do to these values (I guess it acts as voltage amp only and not as current amp). Then till voltage/current values out of DAC. What does Amp do and why does current amplification introduce audio noise? What is the limiting DB/voltage/current value out of Amp? Am sure impedances will also play part here.
So .. all in all .. looking for some kind off Sound Engineering 101 course. Any good reference would also be helpful?
Hope I did not ask for too much?
