somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 6,838
- Likes
- 6,790
I hope you can get hold of a thermometer some day!heres a 2nd copy of the 45xml that just showed up yesterday. first measurement is after it had been installed and on the arm for a couple of hours during the peak hotness of my house. the second measurement is this morning before it has had a chance to get hot in here.
hot
This looks like an Ortofon cartridge, less than a typical AT, maybe AT got som of Ortofons elastomersheres a 2nd copy of the 45xml that just showed up yesterday. first measurement is after it had been installed and on the arm for a couple of hours during the peak hotness of my house. the second measurement is this morning before it has had a chance to get hot in here.
hot
There is certainly an interesting variation of HF responses in the posted Vmx745ML measurements, with similar load capacitances.This looks like an Ortofon cartridge, less than a typical AT, maybe AT got som of Ortofons elastomers
Nasty.View attachment 471662
Thats around 8 to 9 degree rotation. And stylus orientation will cause skipping grooves of often played vinyl. This sales for around 700 US$ here.
Been there too.View attachment 471662
Send it back for replacement!!!View attachment 471662
I center by measurements using NAK T-100 which shows me instant W&F , an then adjust “around the clock” to find optimumGot the 45 RPM Denon test record a few days ago. Testing the 3000 Hz W&F track. No clamps or record weights, record centering was adjusted coarsely by eye (not by USB microscope).
Att 33 RPM:
It does not better my Tacet copy, remeasured today. As seen the centering done by eye is not perfect.
And the Denon record at 45 RPM:
Yes. I may redo this with microsope but the Denon appears noisy. Don’t know why it is so hard to make test records when music works fine. I’ll clean it and return if it gets better. This was a mint sealed copy BTW.I center by measurements using NAK T-100 which shows me instant W&F , an then adjust “around the clock” to find optimum
You may be surprised, but I experienced similar defect in $2000 worth cartridge. Distributer, who I contacted said that this is within expected tolerance. In the end I had to tilt cartridge to get same crosstalk on both channels. Crosstalk is very sensitive to azymith alignment - 1 degree of error causes few dB imbalance.I just picked up an Ortofon Music Bronze, out of curiosity.
It’s hard to understand how a cartridge in this price range could get through quality control like this.
With an extra 20 seconds of care, couldn't the cantilever have been rotated properly?
(Ignore the time stamps)
View attachment 471661View attachment 471660
Sad you hear it was not good , mine was fine. Maybe another pressingYes. I may redo this with microsope but the Denon appears noisy. Don’t know why it is so hard to make test records when music works fine. I’ll clean it and return if it gets better. This was a mint sealed copy BTW.
It's not mine. I was curious how much tilt the previous picture had, so posted marked lines picture.Send it back for replacement!!
