GuidoK
On an ABX test this shouldn't matter.It's more complicated because it's cumulative values during the entire process of capturing and making the disc...
Otherwise an argument like this would nullify any ABX test.
I don't understand what you're saying...On an ABX test this shouldn't matter.
You did ABX testing on this?I have mentioned this before but
1 . Wow defined as peak variation (2S) of 0.4% is clearly audible and will be heard on any music, sound like a battery cassette player with failing battery.
2. 0.2 , not audible on pop and rock, but maybe detectable for sensitive souls on piano.. threshold,,
3. 0.1% is not audible on my music, but audible on test record tones.
4. 0.05 is still audible on test
5. 0.02 is not obvious but can be noticed if you compare with a digital tone.
A good DD and belt drive can do 0.05% , mine does
My question was about when it becomes audible.I don't understand what you're saying...
no abx here..
will you consider the turntables...or the total ?I have mentioned this before but
take the piano, in particular record digitally so as not to add too much wf beforehand...you are in a test situation..you will see that even 0.1% 2sigma, a rather "hard" approach, is already ""a lot""...You did ABX testing on this?
Could you put those files on the forum if you still have them?
So from your testing we can conclude that up to 0.1% W&F is fine when listening to (critical) music?
I mean, all this measuring is a useful academic excercise and yields interesting results from a design perspective when making a new product, but if it's inaudible up to 0.1%, it doesn't serve any real world usefullness for an end consumer to pursue lower values.
And how did you test this?
Did you have decks that had audible W&F and then measured the W&F or did you take a digital original recording and induced artificial W&F digitally (and what pattern) and started listening to the results?
I ask this all out of geniune interest.
How did you test that? What was your workflow? How did you create a 0.1% 2 sigma file?you will see that even 0.1% 2sigma,
I'll let you think about the reasoned methods I was able to use (if you think about it a little you will see it is very simple) ..before thus "verbalizing"How did you test that? What was your workflow? How did you create a 0.1% 2 sigma file?
I'm not really interested in verbal description on what someone might expect, but more interested in how to test it and what, by means of ABX, the results might be.
Just long experience testing turntables with wow and flutter measurements . Be careful with the definitions.I use the peak variation which is close to 2S value, 95% of variation within that number.that is close to what my phone app reports. W&F DIn and JIS WRMS is very different value, much lower numbers, 0,03 vs 0.1 in some cases.You did ABX testing on this?
Just curous since I have not seen info of it; is the phone app 2s value unweighted?Just long experience testing turntables with wow and flutter measurements . Be careful with the definitions.I use the peak variation which is close to 2S value, 95% of variation within that number.that is close to what my phone app reports. W&F DIn and JIS WRMS is very different value, much lower numbers, 0,03 vs 0.1 in some cases.
Virtin test software has files for download with different w&f .
I have recorings of TT with different w&f, and I can vary w&f on my Belt drive , and record the difference and listen to the files.
Turntable rpm say 2S,Just curous since I have not seen info of it; is the phone app 2s value unweighted?
after efforts on the lubrication side, belt choice, choice of belt direction etc etc..but also more in the balancing in the position of the telephone...it is also the values 0.04/5 2sigma 0.03/4 rms that I ended up reaching on a single-motor AC -belt-suspension... become acceptable ...but it remains that dd, which I have, allows a slight improvement which on discs having w&f upstream gives a small margin which can be welcome.. but here values on app gyro without the addition coming from the disc...8Turntable rpm say 2S,
The blue takes peak variation
Fisher MT-6330
An interesting thought. So I attached the gyroscope to the outer edge of the platter and repeated the measurement. There was no difference compared to the measurement in the inner area.
In my plot, the scaling is given in percent. Each tick represents 0.1%.
Is the Denon DP-51F a similar electronic design to the other DPs of the period? I only ask as my recently acquired DP-50M (1978) is running +-0.02% 2S and RMS using the same app.Turntable rpm say 2S,
Fisher MT-6330
Yes, it has that Denon ic, so probably next to do so!Same magnetic sensor head and control board I guess, for details you have to look at the service manual.!
51F has a beefier motor than 47,37,21,23, but not as big as 59/62 and your 50M I guess.
Replace your caps before you get in trouble…
