Lyec motors are what came with Neumann lathes - AM132, VMS-66, VMS-70, etc.The speed fluctuation is about two percent, what kind of records it (Lyrec motor) could be used for cutting, gramophone?
I think for the cutting of this record, a worn out motor was deliberately usedLyec motors are what came with Neumann lathes - AM132, VMS-66, VMS-70, etc.
Meaning it’s dead?Stuffed an MC-2000 today. I wanna cry.
Decapitated.Meaning it’s dead?
Please report back what you think.Some more Fun, I found Analog Magik V1 as secondhand and could not resist…a suitable Xmas gift from my wife to me..
Used once by previous owner.
AnalogMagik V1 Analog Magik for search reference.Please report back what you think.
virtins is very comfortable in imd ... ;-)Very inadequate with stereo track for VTA. Ultimate Analog have the same flaw. How can professionals miss such a basic thing .VTA IMD check must be done by Vertical modulation, the old CBS test records 111/112 use vertial mod. For some reason my REW on my new PC do not analyse IMD so I cannot use that for IMD anymore . ( old PC and Older REW did IMD%..) not sure what I am doing wrong in REW now
So what do the numbers mean? Laterally cut 60 Hz + 7000 Hz tests for LTA IMD, not VTA IMD. Also to relate to music content 60 Hz vertical cut does not occur since bass is in mono. Other combinations should be better eg 370+630 Hz.Very inadequate with stereo track for VTA. Ultimate Analog have the same flaw. How can professionals miss such a basic thing .VTA IMD check must be done by Vertical modulation, the old CBS test records 111/112 use vertial mod. For some reason my REW on my new PC do not analyse IMD so I cannot use that for IMD anymore . ( old PC and Older REW did IMD%..) not sure what I am doing wrong in REW now
you don't need... you have the essential functions that are useful to you in settings available in virtins pro....The cut is 45 degree in phase stereo
Maybe it is a mathematics to extract the vertical movement L R M S ?
L-R should become Vertical mod right?
. I think music content or not is not relevant . iMD increases with tracing distortion as VTA error increases , explained in some old Audio papers , Too lazy to find the link but I posted it here before , google CBS record 111 and 112 that were made for VTA IMD check
my OC9 has a VTA at 20-22 according to DIN test record , and Jico supposedly 30 degrees. The AM IMD is 2.5 times higher for my Jico compared to OC9MLii they have the same stylus and are set up with the same tools and test records . Higher vertical tracing error and higher IMD is expected for the Jico so the results make sense. One day I may fiddle with The VTA in the OC9 TT but I only get 3mm higher Tail end…
Yes someday I may get Virtin too @morillon
Since I got AnalogMagik V1 for Xmas, an V2 upgrade will be the plan for my birthday next year….
Yes VTA IMD error is easily measured with the test records, but not as easily on music programmes.The cut is 45 degree in phase stereo
