But statistical average would be around zero - so no harm if playback stylus is opted for that. Orbray spec is 90°±5°.It's probably a standard distribution, and I'd think a few degrees would be best-case.
Maybe, maybe not. All deviations are naturally within limits. Taking zenith out of the equation (like using a conical); how much cantilever misalignment is needed for it to be measurable and what parameters are affected the most? Channel balance? Distortion? Zenith is quite measurable (phase) as is its impact on inducing out of phase signals, stylus moving up/down instead of pure lateral on laterally cut grooves. I am merely talking about measurable parameters to optimise playback - audibility is different topic.My gut tells me that it is more important to get the cantilever parallel to the groove at the null point , than have the stylus contact point/zenith perfect. After all it is the cantilevers movement that the generator sees.
Rotation of cantilever out of alignment for perfect Zenith would increase the actual horizontal tracking angle error . To bad the Sperling record shown no tracking error effect, we need a record with higher level.
Yes I agree. I've as well been having troubles with time. Priorities.I am still waiting for a conical for my AT540 to confirm the conical result from the old Stanton , but I have to retip a Dynavector too.. and then it’s vacation etc ..hard priorities ..and I would like a dr Feicker protractor
www.audiosciencereview.com
Yes. Same record and conical cartridge though, so it must have been overhang that differed.The positive phase was on another turntable, Fisher MT-6330 , on the Gyro /SME V I cannot twist cartridge enough to make it positive.
Yes. More to come though. There is a smaller effect on the frequency response as well. I have now better sizes of o-rings that match the wands perfect. And I have some stuff at the cartridge end as well to test. When it comes to the shift in crosstalk level - I belive it is due to the small VTA change with o-rings which can be fixed. But the major resonance at 50-60 Hz gets reduced as I expected. Would love to test 12 inch arms but they cannot be fitted on this TT. Longer arms would lower the resonance and it may be below most of the music signals.So the O-ring helps? But the resonance only showed up in the crosstalk measurement?
At 500hz sampling I do not see the golden gate peaks on my JVC QL-Y5FAlex is back with some surprising results for direct drive vs belt drive
Why Don't You See What I See
korfaudio.com
Yes more overhang will shift the phase such that it increases. When positive, then R leads over L. You are going to about -1.5 null points with this overhang shift with a curve shape that is close to the tracking error. Does it follow the theoretical curve when you overlay it with the new app? The remaining shift about -1.5 consists of the combined zenith error of stylus+record. Since twisting limited on the SME, you can only do what is possible. Smaller dimension of the screws? And twisting it will also lower overhang a bit. If I am correct you need CCW twist.@Thomas_A , regarding my Gyro/SME/Oc)ML2 alignement
SME arm head does not allow much slack to twist cartridge. her 1000 hz CA TRS-1003 mono track 3 side 1.
Changing overhang has an obvious alignment effect. minimum phase dgies goes from -4 to -1.6. Sperling record
