- Joined
- Dec 26, 2017
- Messages
- 2,887
- Likes
- 2,517
- Thread Starter
- #2,921
A new TT reports for duty, and it is alive and working.The Denon 51F will be sold.
Have you fully qualifivfed to operate it?A new TT reports for duty, and it is alive and working.The Denon 51F will be sold.
The average channel separation looks a lot closer between the two test LPs than the channel differences, around -25-29 Hz except for <200 Hz.Here's a good demonstration of the crosstalk issue that I have seen with the Clearaudio CA-TRS-1007 and some cartridges.
The following two were taken without any change in setup.
This stylus may have some wear, but it didn't look like much to me. More distortion than expected, though. I don't think the diamond is perfectly vertical.
CA-TRS-1007
Original JVC TRS-1007
You mean an average of -25 to -29 dB, right?The average channel separation looks a lot closer between the two test LPs than the channel differences, around -25-29 Hz except for <200 Hz.
The distortion does look off. I'm in the middle of comparing some styli on a X-1 body and a moderately worn DT-X1II looks a bit more as expected. No shimming.
Hi, no it's the Clearaudio one. I have the JVC with good lateral and vertical tracks, but the L and R sweeps are trashed. Here's the stylusYou mean an average of -25 to -29 dB, right?
This is very intriguing. Your distortion numbers are extremely low for a new stylus, let alone a moderately worn one. This is also with an original TRS-1007?
Here are 2 measurements I did of an X-1 with 2 different X-1 styli. Stylus 1 has a seemingly okay suspension with unknown use, the other has a practically collapsed suspension and is likely unused.
I'll have to try the X-1II stylus in the X-1 body, though I don't expect a big change.
View attachment 538472View attachment 538473
Thank you! I will have to do some more measurements with the CA-TRS-1007 and take a closer look at my styli.Hi, no it's the Clearaudio one. I have the JVC with good lateral and vertical tracks, but the L and R sweeps are trashed. Here's the stylus
View attachment 538571View attachment 538576View attachment 538573View attachment 538575... which actually looks less worn than I remember it.
Hi Laush - I think I saw you on the Waxwing thread - doesn't the Waxwing have a method for crosstalk, for which you can use the 1 kHz tones on the Ortofon record? You can also measure crosstalk across the 20-20,000 Hz range of the TRS-1007 with the online phono cartridge response script. If you have easily adjustable azimuth, very slight changes can bring the left and right crosstalk traces closer or further apart in amplitude using the script method. I would pay less attention to less easily localized bass frequencies and above ~10,000 Hz, where it varies a lot between different tracks or copies of the Clearaudio TRS-1007.Good morning, I have two test records: CA-TRS-1007 and Ortofon. When measuring with the CA-TRS-1007, the crosstalk for some t4p phono cartridges looks strange. How can I use the Ortofon test record to check crosstalk? Will the script https://sjplot.com/online/ work correctly for this functionality only?
Thank you and best regards.
Hi, you noticed correctly - I have a waxwing. My turntable is a Technics SL-10 - linear with a T4P mount without the possibility of azimuth correction. I use the script and TRS-1007 test record, but as I wrote earlier, the crosstalk response is strange for some phono cartridges and I would like to check it using an Ortofon disc.Cześć Laush - chyba widziałem cię na wątku Waxwing - czy Waxwing nie ma metody przesłuchu, do której można użyć tonów 1 kHz na płycie Ortofon? Możesz także mierzyć przesłuchy w zakresie 20–20 000 Hz urządzenia TRS-1007 za pomocą skryptu odpowiedzi na wkładkę gramofonową online. Jeśli masz łatwo regulowany azymut, bardzo niewielkie zmiany mogą zbliżyć lub oddalić od siebie lewe i prawe ślady przesłuchu pod względem amplitudy za pomocą metody skryptu. Mniejszą uwagę poświęciłbym częstotliwościom basowym, które trudniej zlokalizować i przekraczają ~10 000 Hz, gdzie częstotliwość ta znacznie różni się w zależności od utworu lub kopii Clearaudio TRS-1007.
If you mean using the Ortofon sweeps, you can record them into Audacity, then use Thomas_A's Nyquist filter at the Nyquist prompt (> Tools > Nyquist Prompt) see here. Then you need to create two .wav files, one for the left channel and one for the right channel. Trim exactly at the beginning and end of the frequency sweep. For the right channel .wav, use Swap Stereo Channels in Audacity. Use the Advanced tab in the online plot, import the left and right .wav files, set Sweep Extraction to No Extraction and the frequency range to 800-20,000 Hz.Hi, you noticed correctly - I have a waxwing. My turntable is a Technics SL-10 - linear with a T4P mount without the possibility of azimuth correction. I use the script and TRS-1007 test record, but as I wrote earlier, the crosstalk response is strange for some phono cartridges and I would like to check it using an Ortofon disc.
To be accurate JPs correction is the correct one here:If you mean using the Ortofon sweeps, you can record them into Audacity, then use Thomas_A's Nyquist filter at the Nyquist prompt (> Tools > Nyquist Prompt) see here. Then you need to create two .wav files, one for the left channel and one for the right channel. Trim exactly at the beginning and end of the frequency sweep. For the right channel .wav, use Swap Stereo Channels in Audacity. Use the Advanced tab in the online plot, import the left and right .wav files, set Sweep Extraction to No Extraction and the frequency range to 800-20,000 Hz.
www.audiosciencereview.com
ThanksTo be accurate JPs correction is the correct one here:
Frequency Response Test Records
So now we know it the first original that has the blip at 12k, and Issue 2 that has no blip, but a possible drop in one channel . I will test my issue 2 this weekend.www.audiosciencereview.com
