Jimi Floyd
GREAT! Thanks again.W&F Analyzer
myhi.fi
Still a work in progress... https://www.audiosciencereview.com/forum/index.php?threads/the-w-f-analyzer-project-uberrimus.70099/
myhi.fi
Thank you JP, another gift from you I am enjoying a lot after the cartridge frequency response tool. One more thing, is there any clean way to print the W&F plots produced by the web app? Have a nice day!W&F Analyzer
myhi.fi
At some point it will. Want to get the metrics sorted first. That has been an interesting journey.Thank you JP, another gift from you I am enjoying a lot after the cartridge frequency response tool. One more thing, is there any clean way to print the W&F plots produced by the web app? Have a nice day!
WOW
sorry, I said printing but I was thinking how to get a pdf file...Snipping tool in Windows, but why print?, I take a Snip and paste into PowerPoint where I document my work..
Will look at it in the week-end.Anyone want to help sanity-check this? https://docs.myhi.fi/tools/groove-geometry.html
It's reversed-engineered from a couple screenshots of LD's "groovy" spreadsheet, some clues from Yosh's site, and AI.
On the phone I can’t change stylus dimensions. Fixed at 5.Anyone want to help sanity-check this? https://docs.myhi.fi/tools/groove-geometry.html
Wasn't fixed at 5, but the field wouldn't let you clear it completely. Fixed.On the phone I can’t change stylus dimensions. Fixed at 5.
I don't really know what to put in for static and dynamic compliance when it is given only one value for e.g. 10 Hz.Wasn't fixed at 5, but the field wouldn't let you clear it completely. Fixed.
I didn't know that...interesting!first try with rejuvination with LiquiMoly- power steering leak stop-
before..
will have to wait and see now
I just want a make a note on this as a follow-up. For an image shift to happen in the phantom image, the limit is around 10 µs shift around 1000 Hz, according to some publications I've read. During optimum conditions. This corresponds to a phase shift of 3.6°.So I've been playing around with my older Shure V15Vx body, installed it on my 4 g arm wand, set it with the arc protractor and tested 5 stylii with the Sperling record. Three JICO SAS B (new and two old ones), JICO SAS Z (hardly used), and original Shure. Conclusion is that stylii differs...
First off the current, quite new JICO SAS B stylus:
Stylus 2, JICO SAS B.
Stylus 3, also a JICO SAS B, aged.
JICO SAS Zirconium, hardly used:
Original Shure beryllium/MR stylus. Worn and slightly skewed cantilever (towards R channel).
You threw me for a sec - you're talking about the tonearm LF mechanics calculator now. Dynamic you can use 10Hz or 100Hz values. Static is more difficult as it's not published reliably. For that you have to back in to an approximation by seeing if other outputs make sense, like the damping ratios, min VTF for edge-case tracking, etc.I don't really know what to put in for static and dynamic compliance when it is given only one value for e.g. 10 Hz.
Yes, sorry, you are producing so many apps now.I think the results with the Groove geometry app are in the ballpark when comparing to the Sperling record for the Groove Geometry.. Tracing distortion goes from about 0.25 to 1 % for a 1 kHz signal, at ≈2.5 cm/s. Below.You threw me for a sec - you're talking about the tonearm LF mechanics calculator now. Dynamic you can use 10Hz or 100Hz values. Static is more difficult as it's not published reliably. For that you have to back in to an approximation by seeing if other outputs make sense, like the damping ratios, min VTF for edge-case tracking, etc.
