Fun with vinyl measurements
Very curious what inter channel phase difference you get. I cannot get below max deviation of - 2 . And I cannot adjust my cartridge more . I need to set up my experiment TT with my AT VM540ML
Yep. I want to cross-correlate that to the CA-TRS1007. If you record the first 1 kHz pilot tone of CA-TRS1007 what do you get?
CA TRS-1007 and my Sperling is in the same ball park..here compared with your data on CA TRS-1007. Not sur why my OC9ML2 is so far off, does not look bad in microscope...Maybe the fact that it goes though a SUT has an effect?
Ultimate analog phase diff:
finlally a single L&R 70uS test pulse from Toshiba record
Odd. Is the arm mounting distance pivot to platter center perfect as well?
Tried to shift the SME V sledge back and forth- changing pivot-spindle change-,, about 4 steps of 4mm each.. best result with almost max overhang/ minimum pivot-spindle which is clearly off from both SME aligment tool and a normal protractor.
I THINK i made the correct conversion from phase diff to HTA error, AI agreed with me , but I am not sure
Hm. I remeasured mine today since I've fiddled with a new better shim. Now goes from +0.4 to about -0.4°, there is a slight turn counter-clockwise in the headshell. I should perhaps increase antiskate a tiny bit, it does seem to correlate with the distortion graph.
Check the SUT perhaps. Would not suspect it but you never know. Still suspect the stylus. Not easy to get the contact facets clear on a photo.
@Balle Clorin,
is your arm pivot to platter center 215.35 mm? Just checking.
Just now 214mm , but tried variation 210-225 without success, SME spec is 215.35 for 9.5mm from stylus tip to mounting holes
I am out of ideas. Something is off though.
Even stranger the SUT is in bypass mode . Have to experiment a different system to see how system respond to more dramatic changes
Even stranger the SUT is in bypass mode . Have to experiment a different system to how system respond
I can only think of zenith error.
By the way, I think Wallytools may be right regarding zenith correction. Ater twisting the cartridge to reduce zenith there may be a bit of more detail and coherence to the sound, less smearing. All subjective of course. Systematic testing for it would be quite exhaustive.
233.15 if I recall correctly ,SME V
Audio Technica ATOC9MLii stylus distance 8.75mm stationary. Maybe 9mm spinning? VS SME V that is based on 9.5mm mounting hole to tip distance. So I am about 0.5-0.7 mm less than the 233.15 spec effective length.
With your effective length being approximately 232.65 mm, you need 214.82 mm pivot to spindle distance and 17.83 mm overhang to reach the Löfgren A null points. It's funny that it would require so much more overhang.
The pencil leads look misaligned on the outer null, too..
Played around with the Sperling record yesterday, will continue today and report. First impression is that my original geometry seems basically correct (curve shape) but there is a need for zenith correction. It was a bit of a pain to correct it though; and I am on the learning curve for very very fine adjustments.
Just a quick reminder, among all the adjustments, protraction on our pivoting arms is one of the most relative... ultra-precision to a tenth of a millimeter, or even a millimeter, is laughable...
It's quite fundamental not to forget that...
