- Thread Starter
- #2,421
setting anstiskate by intermodulation distortion testing. More antiskating tetsing using AnalogMagik V1 45 rpm record- 45/45 stereo modulated VTA 60:7000 Hz IM test..'' First track on record
Setting Antiskate AS= VTF value maintains consistent IMD values
But changing anti-skate for will possibly skew the stylus/cantilever... here is the effect of 1.75g and antiskate of 0-1-2-3 Left channel,only, right behaves the same...
Then lowering the VTF give even higher % AS side force... more push on cantilever angles
So high side force 20% of VTF( VTF 2.5 AS 3) gives lowest %IMD, but 20% side force is unreasonable high, so i think my stylus should be tilted a bit to match the tilt it has at high AS force.. This tests could be done on Tacet and AP Ultimate test record too, but I am too lazy now
Any comments to which I should adjust first, Azimuth or horizonal angle/zenith?
Script to make plots are in the attachment, rename txt to py
EDIT. AP ULTIMATE TEST RECORD , same improvement by higher Aantiskate. BUT NO RESPONSE TO VTA CHANGE( PLATETR MATS ADDED)
