RayKay
- Joined
- Feb 4, 2022
- Messages
- 13
- Likes
- 42
@ElectricWarrior,
If I may, I’d like to posit the idea that not only is there a sliding friction for the stylus on vinyl but, the stylus/vinyl interface also exhibits sticktion. Stylus sticktion would account for at least some of the difference seen between the two videos.
In the second video, VTF pushes down on the cantilever suspension and causes the stylus to move forward as the cantilever rotates upward from the VTF bearing down on the suspension. Stylus sliding friction adds a pulling force on the suspension, which ends up deflecting the cantilever upward and the stylus forward even farther.
In the first video, VTF pushes down on the cantilever suspension too, but stylus sticktion inhibits the stylus tip from sliding forward and allowing the cantilever to “stretch itself out”, so to speak. I believe that in this scenario, forces would also resolve into a lateral component that would cause some sideways deflection. It would be informative if you could repeat the same video sequences except with the camera viewing the cartridge and cantilever head on to see if there is sideways deflection.
These effects would indeed hamper alignment accuracy through having some effect on effective length, but might also skew the cantilever sideways and directly add an angular error to the procedure which may be worse than a small change in effective length.
Thoughts?
Ray K
Thoughts?
Ray K
