Full Range Speakers, under $5k
And how exacty would they corrected that with passive design?
Dips like that are hard to equalize in a passive design. You have to bring down the level of everything else. Sacrificing sensitivity is generally not worth it.
RE: R11
https://www.soundstagehifi.com/index.php/equipment-reviews/1300-kef-r11-loudspeakers
https://www.soundstagehifi.com/inde...nded-reference-component-kef-r11-loudspeakers
Note the funky dip at 60hz.
There is a Best Buy/Magnolia less than a mile from my home which has these set up.
I have no idea where I could find a pair of Canton's.
Nearest retailer for Revel is in Austin, 3 hours away. Local Revel resellers are home automation/theater guys with no inventory.
The dip is a measurement artefact. A bit lazy to link the source, but the NRC anechoic chamber is anechoic only down to 80Hz. They got access to someone else's anechoic chamber that was good to 20Hz and derived a compensation curve/algorithm that compensates from 20-80Hz. However, this compensation very frequently goes wonky in practice in the measurements the NRC makes for Soundstage. It is not reflective of the actual performance of the speaker.
Dips like this are NOT equalized with passive XO as it would require far too complex filter design.
If the source is a computer, with quality software like PEQ from JRiver MC, we can adjust the dip without damaging other parameters, provided it is not a very aggressive equalization.
[IMG, link] https://www.audiosciencereview.com/forum/index.php?attachments/jrmc-dsp-peq-kef-q100-png.32987/
BTW, now that nobody reads us: I usually listen to my little ones in the near field, hence I have always complained about lack of depth in the sound. The other day, doing tests with the different functions that the JRMC PEQ incorporates I was fiddling with the delay. In the end I left it at 5 ms for both and the sound is better, with more depth. :)
Only activated with music. With video the voices are out of sync!
Canton seems to be online-only in the US, so if audition is a consideration, yeah they're out. The pricing on sale (links in my original post) is very good, they go on sale much more than Revels do, so there's that.
I'm considering getting a pair of passive speakers which have enough bass (flat to below 30hz) to not need a sub, extreme bass heads excepted. The Revel F208 looks interesting. Any other ideas?
Let me suggest, also, looking at the Bryston speakers.
RE: R11
Where are you located. Maybe I can accommodate an audition
Welcome to Canada! 20 year warranty, heck I probably won't last that long. Dealers in Austin and Beaumont TX.
I can listen to the R11 at Bestbuy, it's literally within walking distance.
Are your saying that delaying the sound to all drivers equally sounds better than no delay?
You could always look at Axiom who builds Bryston’s speakers.
Reactions: 617
First I tried, of course, with a single channel and was alternating. When I decide to try with both the sound improved! At first too echo, 50 ms. I went progressively down and stayed with the 5 ms. It sounds better in near and far field too.
340 m/s and 5 ms -> 1.7 m
PS: playing Peter Paul & Mary from foobar2000 with DSD : KS : JRVAD Wave thanks to JRiver MC WDM driver.
Why? Register me. Maybe it is JRMC thing. For example if I set the resample option, even if I do not use it for the music I am listening to, the sound is worse. And JRMC SoX is worse than the one implemented in other soft players and also does not allow configuration.
Even if this is off topic, I find time delay to be interesting. Is it possible to apply the delay to a particular frequency (over 100hz) to time align a sub with the mains or does the sub have to be on a different channel? It wouldn't make sense to delay everything.
RE: R11
NRC’s measurements are only valid down to ~100Hz, as their chamber is not large enough for full-range accuracy, almost every speaker they measure has a dip ~80Hz; which obviously isn’t true to life, they use a compensation curve that they arrived at by measuring a speaker in a larger chamber and comparing results, it doesn’t work well.
EDIT: Didn’t see Ilkless said the same thing. Source:https://www.hifiplus.com/articles/p...ded-tour-of-canadas-nrc-acoustics-labspart-1/
With JRiver MC nope. At least from the PEQ (btw, it works with minimum phase as the old analog).
How would I do that in Rephase?
Speaking of crossovers, I have the F208 and although I’m happy with them, would there be any advantage to me upgrading the components with same values (RLC values)/better quality?
Chris
