FS/UK Custom 12" Sealed Subwoofer (Passive)
montyliam
Manchester, UK
Hi guys, for sale here is a newly built custom 12" sealed subwoofer. For a little more information:
The driver:
  • Celestion FTR12-4080DL
  • High-sensitivity pro-audio driver with longer than usual xmax (around 14mm)
  • High continuous power handling (1400w)
  • High BL (strength of the magnet, 24Tm vs the usual 15Tm for a 12") + low moving mass means very snappy transients.
  • Able to be used higher than 200hz (makes crossover with mains easier)
The box:
  • 18mm MDF, double thick front baffle
  • Rigid interior bracing
  • Finished with Tuffcab pro non-reflective and scratch resistant satin black paint
  • Speakon connector on the rear for use with pro-amplifiers
  • 550h x 333w x 254d mm
  • 4 rubber feet on the bottom
Please note this sale is for the passive subwoofer only, not including the amplifier (currently using Behringer A800). You will need around 6-800watts to take full advantage of the driver in this cabinet. Luckily, amplification is quite cheap nowadays (the above amp is £150 and works excellently for this application).
Asking for £250 (the driver itself costs around £230). You could have an epic subwoofer system for around £400. Comparable subwoofers would be the SVS2000 series (starts at £1000).
Reason for sale: I need dual subwoofers for the new space I am in, unfortunately I now do not have the space or time to build a second.
Any questions please ask!
Bump. I have tried to find a suitable box for this but as it stands this will be collection only from Manchester, UK.
