After reading posts here, (I'm getting new amp, speakers for 2 way music only system.)
I started looking at specs. of 2 speakers I'm considering buying than realized I don't understand what the freq. specs. are or how to apply to them bass response of said speaker. So I did a google search & came across this article https://www.audioholics.com/loudspeaker-design/understanding-loudspeaker-frequency-response
Which states "The short answer is that none of these frequency response ranges can be compared, for reasons that will become clear."
So bass response (room & room correction ignored) speaker JBL spec is 44-40K HZ. KLH is 42-20K HZ. I thought that the KLH would have better bass response but after reading the Audioholics article I'm now thinking the only way to tell if a speaker is is right for you is to bring it home and listen to it.
Is Audioholics correct or is there a way to actually interpret manufactures specs. for a dummy like me ?
Thanks
Should I "feel" the sound more with floorstanding speakers vs bookshelves?
After reading a lot on this forum, I decided to go try out some revel speakers for a 5.1 home theater setup. I demoed the M105s and F208s as the L/R, paired with multiple centers and a JL audio 12" sub. I listened to various scenes in Interstellar as my test material. The speakers were sitting...
www.audiosciencereview.com
Thanks
