- Joined
- Dec 26, 2017
- Messages
- 2,747
- Likes
- 2,378
So now we know it the first original that has the blip at 12k, and Issue 2 that has no blip, but a possible drop in one channel . I will test my issue 2 this weekend.
Mine is not Issue 2Which version in yours? Issue 2?
No..very strange that the blip was not detected in a single instance,check it with REW and I think you see the blip.
Whoops, I was mistaken. Mine is indeed Issue 2. It says it on the record, but not on the sleeve.Mine is not Issue 2
Are the matrix numbers different for the first and second pressings?it makes sense then Issue 2 has less blip
I took separate photos of the cantilever, the diamond, and the diamond contact line. The recording speed was 16.66 rpm; then, it was increased to 33.33 rpm in Adobe Audition.How did you measure the VTA?
How can the frequencies go to 20k at 16 rpm when it stops at30 at 33?
This is 100% a MicroLine stylus. Do any other diamonds even have this kind of shape? However, this MicroLine isn't perfectly symmetrical: its edges have different lengths and thicknesses, and I think the angles of the edges are different too. And I still don't understand why the crosstalk is so poor, only 25 dB. Maybe this record was cut with an SRA of 15 degrees or less."Yep interesting.
The crosstalk differs around 5 dB, but do not go much below 25 dB. The high frequency differs a bit too, but not much. A pity you did not check the distortion from the vertical 1 kHz track at the same time.
And is this MLa a microfine? Does look more like a hyperelliptical/fine line. Edit: I see now the angle was not the one I thought...
