Frequency Response Test Records
The phase diff curve is not identical to the angle error curve due to the radius effect…I posted a comparison earlier….you need to compensate for the radi and rpm , I have an excel sheet for that
Yes it is not but I am talking about the begniing ans ends. The one below is not correct. I will redo the alignment with pictures of headshell/cart along with it.
I have received the Clearaudio TRS 1007 record. I'm trying to figure out how plotting a frequency works, but i am truly confused by this. I tried using SJPlot online but it doesn't offer the Clearaudio LP as a setting and every plot I create looks totally off by me. like -13db at 10k, -18 at 20k ???
That said, I have to look into my cart alignment I guess because there is a lot of harmonic distortion on the left channel, sweep, not on the right. Or maybe it's the record. No idea.
I have uploaded both sweeps (left & right, summed to dual-channel mono each) declicked at 44.1khz, 16bit. Could someone plot this?:
I would love to correct my setup to flat (using iZotope RX10 & Voxengo CurveEQ)
My gear:
TT:
Technics SL 1210 GR2
Cart:
Shure V15 IV with Jico SAS/B Stylus
Pre-Amp:
Musical Fidelity V90-LPS
Capture:
EVGA NuAudio at 192khz, 32bit using Nero Wave Editor
Also:
Man this record is crackly sounding for a new sealed copy. Jeez
What? Why?
Oh sorry, I didn't mean "summed", but for example the left channel sweep file is the original left channel on both channels of the file. I guess I could have saved that as a mono file in the first place, but I didn't think of that.
Ok, I thought that meant the old JVC TRS-1007 Record.
But anyway, my plots end up looking like there is a massive drop in trebble.
Like "Huh?" ~ -37dB at 20khz ???
It's near flat when I select "Inverse RIAA - Trebble only" but that isn't the correct setting or is it?
Use standard mode and give it one file of both sweeps as described in the linked post. If you recorded it using a phono stage that has RIAA, then select "with RIAA". That's it.
And a tip is to record in 96 kHz. Otherwise distortion plots will drop too early and mess up the y axis scale.
Standard 2 point, I I believe it should work for any arm , but maybe not? .
It is a universal method that works for any arm—IF the slots in the headshell are long enough. This could be a problem here. Most generic protractors are for Baerwald/IEC, which needs a considerably longer overhang than the stock geometry for your tonearm.
Ok. I notice that the arc method has a better accuracy. I can set it with the two point looking good but being a bit off at the very beginning or end of the arc.
Right, the two point method lacks accuracy. I noticed I can be several millimeters off and it may still look fine on the null point grids.
The accuracy by which the angle of the cartridge or cantilever can be seen is very limited. This is a problem for any protractor, but with a two point type an angular error is used to find the overhang, so the accuracy by which the overhang can be determined is limited as well.
The arc sure makes overhang errors very easily visible. But I found I can get a similar degree of accuracy with a llnear offset protractor. As long as the protractor has a second null point grid for double checking, you can't do worse than with a two point type.
Post moved to the thread "Fun with vinyl measurements".
If I use EQ to correct my system, is it a bad idea to do this for each channel individually? they are not the exact same, that's why i'd do it.
But now i've read somewhere that using different EQ for each channel can result in "smearing of the stereo image" ???
Are you talking about corrections to cartridge differences L and right or , speakers room corrections.
I have DSP room correction ( Trinnov) and it manipulates each channel individually. But the standard to correct acoustics is to do bass only ( below 200 500 or 1000 hz depending on room) correction above 1000-2000 hz is more speaker correction due to more direct sound..
Altering the high range can make strange effects depending in speaker directivity and room reflections.
So putting EQ on a room response to affect cartridge difference may work or may not. Try and see what you like - getting equal signal to the L a d R speaker should be a good start , especially if the channels are not unbalanced within 0.3db
I can use Trinnov or Parks Audio Puffin to flatten the MC Peak or other imperfections ,- as you did in earlier post-, it works fine , but I do not hear much above 10k anyway..
Cartdrige differences
Also: Linear Phase EQ or Minimum Phase? I suppose using different EQs with minimum phase would result in phase discrepancies when recording a mono record in stereo and then summing it down. Or am I wrong? Linear Phase could result in pre-ringing, but I am not doing anything major in terms of EQ. hmm
SFC-TR100 vs CA-TRS1007, Denon XG-7001, Denon XL-7001, Ortofon-TR
cartridge - Karat DV, retipped, 2.5mm cantilever + ML Stylus
Nice. Could you add also Ortofon test record with the correction of its error? Using the below formula twice in the Nyquist prompt of Audacity.
(biquad-m *track* 9.08612614639649000E-01 -5.22931473883012000E-01 -3.44913691685509000E-01 1.00000000000000000E+00 -6.04500910000000000E-01 -3.90945930000000000E-01)
How do you get the 15k vertical line to show?, good retipper it Seems:)
ax.set_xticks([0,20,50,100,500,1000,5000,10000,15000,20000,50000,100000])
ax.set_xticklabels(['0','20','50','100','500','1k','5k','10k','15k','20k','50k','100k'])
I know next to nothing about programming, and I found this line. 15k is important to me because anything higher is usually irrelevant, and very few people even hear anything higher than 15k.
A very minor difference.
Did you apply the function twice in a row on the same file?
Now I applied it twice and applied an FFT filter up to 400Hz.
Thanks, looking better. The EQ formula is a RIAA correction, and the error with the Ortofon is that the time constants were not correct when it was cut in half-speed. I just found using that RIAA correction twice seems to correct it and align almost perfectly with the CA-TRS1007 in the frequency range of 800 Hz - 20 0000 Hz.
