Jazigo
- Joined
- Feb 9, 2025
- Messages
- 143
- Likes
- 119
Hi everyone!
So, a chistmas present for me to me was a Topping D50 III and a pair of B100s. This replaces a set of Topping E50 and a PA5. I expected the B100s to be a complete waste of money, so I was prepared to return them after a day of two.
However, there seems to be a clear difference between the two. I known that i can be biased and sort of hear what I want hear, so I decided to do some measurements with what I have on hand.
From my understanding, frequency-, phase-, distortion (and noise) response should be all that matter for audible changes. So I measured with a UMIK-1 and I made sure that the settings on my signal chain had the same voltage output. I was not able to get the voltage perfect, but I got so close that it would amount to less than a 0.1 dBspl difference on the speaker.
The measurements:
(edit): They both use the same DAC, the topping D50 III in the measurements above.
As one can see, no meaningful differences in the output of the speakers. Does that mean that I am just biased? I am happy to admit it if the science is clear about it.
The main differences that I can see in my signal chain is that I know use 0db gain on B100s compared to the 19.1db gain on the PA5. This means that I have to set the DAC to -21.5db with the PA5 and -2.5 on the DAC with the B100s to get the same volume.
Could be that the gain staging is doing the differences, but that does not show up in the response? I was also thinking about maybe checking some SMPTE/DIN distortion. Maybe that is affected by having the DAC at a lower volume.
Subjective perspective (feel free to skip):
I mainly use this system for playing games, which often can have very complex sound stages that have a lot of effects going on at once and two things stands out admittedly when listening:
The measurements:
- Small sound effects are not so muted (while a lot is going on), like they were Motown mixed (every instruments have their on frequency range and they are not allowed to bleed into each other range)
- It sounds effortless for the amplifier to produce all of these sounds as once.
