Do you know your interaural coherence coefficients?
Find out now.
http://www.audiovero.de/en/downloads.php
JBL LSR 308
MartinLogan reQuest and Cheezewoofers
(no DRC applied on either one above)
With some DRC applied:
JBL (about the same, no change)
ML (a little positive change)
It was this Archimago post
https://archimago.blogspot.com/2015/11/measurements-digital-room-correction.html
"As you can see with my sofa moved aside and no coffee table in front of the speakers, I'm getting 69% which looking around at others' results seems reasonable for a domestic sound room without a large amount of room treatments. 80's would be awesome and I'm amazed at Mitch's achievement of 90's - great! For the purpose of the room correction, the data from the first 10ms would be most important."
... that made me curious.
He's referring to this, posted by @mitchco:
https://www.computeraudiophile.com/...me-Alignment-Driver-Linearization-Walkthrough
"Please note that an average setup results in an IACC around 75% based on Uli’s experience. Higher IACC values, like what I have obtained (88.5% and 87%), does require very careful setup and consideration to room design, as I have outlined in the system under test section."
Find out now.
JBL LSR 308
