Four mono amps to power speakers safe?
olds1959special
Los Angeles, CA
“CAUTION! Many amplifiers will oscillate at very high frequencies when cap coupled with no DC return path (this always is the situation for the amps driving the Mid/Tweeter section) unfortunately there is no way to know without a scope until the tweeters mysteriously burn up. On may hear this if the sound gets brighter but some would find this as a possible improvement especially if they are older. I recommend one finds a mono amp he or she likes and bi-wire with short speaker wires. RV“
I am using Kenwood L-05M’s. How do I know if they are oscillating at high frequencies?
That should NOT be a common problem. Most amplifiers are stable and don't "freak out" with no load. (You might get more ultrasonic switching noise from a Class-D amplifier.)
If you're worried, add a 1K resistor across the output terminals. That should be enough of a DC path.
You might need a resistor rated for 1 Watt or more. Power can be calculated as Power = Voltage Squared / Resistance. From my quick calculations, 20V (which is 50W into 8-Ohms) would be 0.4W into 1K.
[/qutoe]
Bi-wiring is different from bi-amping. Bi-wiring is useless except it doubles the wiring, similar to using heavier gauge wire.
