Found the engine for my next car....
You been hanging with Jay Leno or something? Electric is still more impressive I think
The 1953 Mirrlees JS8 engine that was fired up on YouTube has an interesting history. The problem, however, is that the team behind its resurrection doesn't have all the exact details. What's certain is that this somewhat obscure diesel engine was originally ordered by the Air Ministry and delivered in 1953. It appears to be an auxiliary power unit (APU) and may have been used as a backup generator at an RAF base in Scotland. Additionally, the engine has an air-start system instead of a conventional starter, making it even more unusual.
The JS8 engine comes from Mirrlees' J series, which the company began developing in 1947. It was designed for use in a variety of demanding applications, including marine equipment, locomotives, oil fields, and power-generation systems. The eight-cylinder version had a 9.75-inch bore and a 10.5-inch stroke, resulting in a total displacement of 102.4 liters. The J series covered a wide range of configurations and power outputs, from 135 to 2,480 hp and operating speeds from 600 to 1,000 rpm.
Mirrlees didn't stop with the J series, as the company eventually developed even larger engines for both power generation and marine use. For example, the K Major was offered with power outputs reaching 13,140 hp. However, the company's most powerful engine was the MB430, which could produce 1,000 hp per cylinder, making the biggest version capable of producing 16,000 hp.
JSmith
Found the engine for my next car....​
Maybe so, but I see a workplace hazard and about 16 OSHA violations... not to mention the obvious environmental issues.
So what was that, a marine engine?
Edit: I just read @JSmith's post.
Many old guys...waayyy to experienced with big engines... Tend to skip any type of usual sense of worrying and jumps straight to working, with minimum care for dirty fingers, eyes, ears, skin exposure and the like. They almost think that the more 'worn' they are, the more cool and daring ... Like a self-sacrificing thing for the greater good.
Impressive engines for its time... But modern engines are even more so, when you look into details.
Fully functional (but no reverse, of course ;-)
I got a kick out of the one mechanic standing right next to it without any hearing protection!
Do you visit air shows? Often they have the big motors in active display on carts, like any version of Rolls Royce Merlin (WWII british warbird motors, also use in the P51),
Amir,
Consider getting around the Seattle area using a vintage unlimited hydroplane like the 'Miss Bardahl' from 1962.;)
A 3,000 horsepower, Rolls-Royce Merlin III engine built by Packard.
An excellent tool for removing significant parts of your body. :oops:
You might be a redneck... if you use your pickup truck as a starter.
I worked on a ferry... Used a Mitsubishi engine, S6R as back-up... if i remember correctly .... Had to pump up a nitrogen rubber ball that sat inside a hydraulic tank with a 1m iron bar - manually - to run the starter motor... To start the ship from 'dead' so to speak. Fun times, being 3'rd in row machine officer.
With the price falling by a whopping $0.0046/gallon, today is a great time to invest in a 102.4L diesel engine
