Also a new member as well, great to be here! I found you folks in a search about the ZH3 and this looks like the place to be.
I did a quick search here for the topic or info I'm about to mention and I didn't find anything so here goes:
There are a few things about this preamp that no one talks about or mentions anywhere. Before buying make sure you read the user manual and don't rely on youtubes etc. because no one mentions it. What I found was that I'm having to return this preamp for a specific set of limitations that some may or may not be aware of before you buy one of these, and the issues are:
1. If you intend to use the USB input from a PC or Mac as your source and the XLR outputs to an amp and want to use the front knob for it's volume control feature, you're forced to use it in AUX mode. In AUX mode UAC switching, EQ, Bypass and Gain are not supported.
2. If you're intention is to hook it up to an Xbox, Playstation or Nintendo Switch then you're golden. If, however, you intend to use it as the "audiophile" device that it's advertised as and are still willing to forego using the ZH3 EQ, Bypass and Gain bear in mind that as you can't access UAC 2.0 you're limited to 16bit/48k resolution.
Basically if you want to use the volume knob to separate external amps it's best use if for gaming etc. not audiophile use. If you want it specifically for the headphone preamp and external amps don't matter it's still ok.
In my use case I intended to offload as much conversion as possible to the preamp expecting higher quality audio processing from it than a Mac is capable of.
If I'm wrong I'd love to know what I got wrong though as most of this info came from Fosi customer service reps.
