- Joined
- Feb 17, 2023
- Messages
- 94
- Likes
- 55
It’s no problem, I’m getting exceptional sound out of the headphone output so I can’t complainThis is due to hardware limitations, RCA and XLR do not support EQ adjustment;
Any chance to share it? Ive reached support over email and on fosi forums but no aswer yetYes, we have updated the new software, and many customers have already solved the problem of music disappearing before 300ms after updating the new software. If you need it, you can contact our customers to collect the firmware;
sure.Any chance to share it? Ive reached support over email and on fosi forums but no aswer yet
6.35mm headphone jack -600 Ω -34mW;Is there any chance it will drive DT 880 600 Ohm 96 db?
im having this issue in windows 11 when playing a new track, or video the sounds mutes for the first half second. I remember i had this same issue with another xmos device and used this thread to fix it: https://www.audiosciencereview.com/...os-driver-settings-for-no-cutoff-delay.25838/ however it doesnt seems to work anymore, anyone experiencing the same? any fix?
its like the dac goes into sleep for half a second when an audio track changes.
If i cant fix it ill be returning it, its driving me insane.
problem solved with the firmware update fosi support sent me!im having this issue in windows 11 when playing a new track, or video the sounds mutes for the first half second. I remember i had this same issue with another xmos device and used this thread to fix it: https://www.audiosciencereview.com/...os-driver-settings-for-no-cutoff-delay.25838/ however it doesnt seems to work anymore, anyone experiencing the same? any fix?
Yes I replaced the opamps with V7V and am very happy with the sound. I had noise on the analog (RCA) input at volume level 24 and above (zero noise with digital inputs). After switching to V7V the noise is gone, but it could be I had a faulty stock opamp or one came loose in transport. The sound with the stock opamps was really quite nice so I didn’t think anything was broken until I changed op amps and there was noticeably less noise with high levels (24-32) on RCA input. Maybe it’s just my unit, or perhaps this is a case where op amps are not equal. It sure made an audible difference for me…Anyone tried replacing the opamps ? Does the Burson V7V fit ?
Thx in advance !
Yep that’s correct. I use the SE headphone out with an adapter to RCA so that I can use the EQ for my other amps...if I understand this correctly the PEQ only works on headphone output and not XLR or RCA out...???...
I’ve been using Topping DX5II as the main DAC in my chain now...interesting if inelegant...it is not like you would use headphones and audio system simultaneously...
...this new data makes the Fosi ZH3 with its RCA input a good bit less attractive and renews some interest in Topping DX5II...
...that solution you suggested would work with any such amp...
If the ZH3 had the option to have ALL outputs active WITH eq, it would have been a much closer competition. With each offering different options to customize the sound profile to taste…I’ve been using Topping DX5II… all 3 HP + RCA + XLR OUT are active at once. For that reason alone I’d choose the DX5II > ZH3
No problems driving the DT880/600 to 114dB peaks.Is there any chance it will drive DT 880 600 Ohm 96 db?
No problems with driving this 101dB/V sensitivity headphone to at least 106dB peaks (somewhat loud)Can I use moondrop para with fosi audio zh3? Because it mentions between 16 and 300 ohm headphones. Is there any clipping risk or any risk for low impedance (8 ohm, 80db/mwsensitivityefficiency) headphones? Thanks.
...I most likely would have selected Fosi Audio ZH3 over Topping DX5II because of the RCA input if this was the case...what were they thinking...?!?...If the ZH3 had the option to have ALL outputs active WITH eq, it would have been a much closer competition. With each offering different options to customize the sound profile to taste…
