- Joined
- Feb 17, 2023
- Messages
- 94
- Likes
- 55
Using different speakers with different amplifiers will not help you diagnose the problem imoI have massiv problems with the RCA analog inputs. Going from the DX3pro with 5m cable to the RCA inputs to the other side of the room I get massive his. Speakers are ADAMS connected with XLR.
If I connect the cable with the PAII at the same location of the fosi and same power plug (but going into passive speakers) - here is no hiss at all.
If you can use the Fosi as a preamplifier into the pa ii + passive speakers then you can attenuate the Fosi until you do not hear anymore noise. I found the range from 24-32 to be unusable with my most sensitive headphones due to noise, so it would have been nice to have the RCA input + RCA/XLR output measured here
