Fosi ZH3 Balanced Headphone Amp & DAC Review
Rate this DAC & HP Amp
    Votes: 2 0.8%
    Votes: 9 3.6%
    Votes: 72 28.9%
    Votes: 166 66.7%
This is a review, detailed measurements and listening test of Fosi ZH3 balanced stereo DAC and headphone amplifier/preamp. It was sent to me by the company. I can't find the price ($200?). It costs US $199.
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp balanced review.jpg
The ZH3 is attractive and follows the design language of the newer Fosi products. I found the menu navigation with the front panel knob difficult. It would sometimes jump forward/back with little motion, other times it would take a few clicks. It was very frustrating. Fortunately the remote control doesn't have this issue. Back panel shows attractive set of features:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp balanced back panel review.jpg
Like the inclusion of trigger and RCA inputs. Alas, I forgot to test that. :) Will do so later.
In the interest of time, I skipped over a few tests and focused on front panel headphone outputs only.
FOSI ZH3 Measurements
I started with medium gain and balanced headphone out:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp Measurements.png
Distortion is well below threshold of hearing. So SINAD is determined by noise alone. 113 dB nicely lands the ZH3 in our very competent bucket:
Here is the dynamic range:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp dynamic range Measurements.png
At 4 volt, performance is more than you could ask for in this class. At 50 mv, initial measurements using balanced out was somewhat disappointing. Switching to unbalanced, remedied good bit of that:
Still, highly sensitive IEMs may experience a bit of noise.
IMD test shows the difference between balanced and unbalanced:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp IMD Measurements.png
Default filter performance is typical and good:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp Filter Measurements.png
There is almost no frequency dependency which is good:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp THD vs Frequency Measurements.png
Now we get to the impressive part which is available power and lack of any distortion/clipping:
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp Power 300 ohm Measurements.png
Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp Power 32 ohm Measurements.png
It is especially impressive to see no clipping all the way up to 2.5 watts! I don't think I have seen this before. This is very useful for testing limits of headphone distortion. If you hear any distortion, it is the headphone and not the amplifier!
Fosi ZH3 Listening Tests
I chose to test the Dan Clark Audio E3 headphone with the ZH3. I used the high gain and with it, there was incredible fidelity and lots of headroom. I think I had the volume at 75 even at very high loudness. Detail in the music was amazing as was the bass impact. The combination melted my heart in how clean and dynamic the performance was!
If the price is as I expect, the ZH3 is an incredible offering with ultra low distortion yet a ton of power. It is attractive in design and capability. Listening performance was a delight even with my less sensitive headphone, proving the capability of the output stage. Yes, the noise figures could be a bit better but that will impact very few users with ultra sensitive IEMs.
The inclusion of analog input is a major hit for people like me who also need to integrate an analog source. Few DACs sport such a feature.
It is my pleasure to recommend the FOSI ZH3. Company sure has its eye on the ball as far as feature list and performance.
  • Fosi Audio ZH3 All-in-One Desktop HiFi DAC Headphone Amp Preamp Power 300 ohm Measurements.png
Does it support RCA IN -> RCA OUT bypass with fixed volume?
Can you set fixed volume from other inputs to RCA OUT?
What would be the use for that?
If it's intended to work as a DAC/preamp too and not only as a headphone amp, in my opinion this feature should be supported. At least in the Fiio K7 this is possible and I think ZH3 is very similar in features to the Fiio.
Does the dynamic range vary from low gain to high gain?
Low and medium gain are the same. But there is a noise penalty at high gain as you see in the power measurements. Not an issue in that regard in that only an insensitive headphone needs the extra power.
@amirm How's the multitone performance?
As I noted, I skipped over some measurements as I have a horrible backlog and yet to take a summer vacation. :( Given the extremely low distortion at 1 kHz, I predict it would be excellent anyway.
Good to see Fosi steps further with another decent dacamp. As always, thanks for the measurement o7
btw, Fosi zh3 offered different types of filters according to the officials, I think the THD+N level vs frequency might change dependently
I may be incorrectly reading the detail of this review.............
The graph showing Power versus Distortion Using A 300 Ohm Load appears twice - just before the graph detailing Intermodulation Distortion, and then later in the section measuring available power and distortion.
In a desktop setting, I wonder if I would become annoyed at having to rely on the remote control to access the menu of a Fosi Audio ZH3 instead of reaching to use the knob on the front panel ?
Thank you for the review.
The officials said that all features are designed to be controllable via the knob, the remote control is made for scenes like where you are far away from the dacamp :)
