Fosi ZD3 keeps shutting off.
Joeyd33
Got this straight from Fosi, using the USB connection to my macbook pro (still looking for my optical cable to test it out with my pc!".
Problem is after a certain point it starts to distort for about 10 seconds and then the noise just cuts off.
It's out in the open,all the connections seem fine. I am using 2 connections, XLR to XLR and RCA to XLR.
I wonder if its the dongle I am using for my MacBook pro so that I can use the printer to USB-a cable to usb-c
Heres the dongle:
To double check vs your hub I would just get this cable to use direct to the MacBook.
Edit: as well as just adapters for the cable you already have as an option to.
