Fosi ZA3 opamp bypass
Ixnay
I've always been a tubular guy but that Fosi ZA3 falls into an "interesting experiment" bag. Unfortunately, there are apparently opamps in the signal path, which is something that I would prefer to avoid. I suppose that they would be necessary to get the input resistance that they want, but maybe that's something I wouldn't worry about so much.
I wonder what would happen if I jumpered the socket pins input to output on the ic's. I'd probably lose gain, I'd probably lose input resistance, but so what? I never play it very loud.
I expect sniffling hysteria in the responses, as usual.
There's only one way to find out for sure...
'Tis true.
Not a real good time for splooging on toys. I just bought a house that I can't afford. But maybe some day I'll go nuts and give it a whirl.
It's not possible to know without experimenting. To avoid the cost, you could model the ZA3 in spice with and without the op-amp to see what you get. My instinct is that it bypassing the op-amp will stop the device from working.
