TLDR: I received 2x Fosi V3 mono with 2x 48V 5A.
Their phase is correct. they have 19-25dB gain switch on RCA. They have only 1 QC sticker.
They don't make any concerning amount of noise when turned on and off, even yanking or plugging in at mains with switch on amps set to "On".
They are not disturbingly warm after a few hours use at moderate volume, though the room is pretty cold at present.
They work. Music is being amplified and sounds as such. success! but it's only been mere hours.
I just received a pair of Fosi V3 Mono today, with 2x 48v 5A power supplies. (Previously had and was using Fosi v3 stereo. 32v 5A power supplies)
I personally think external power supplies are often favourable, and do not wish for internal.
The models delivered are both 19-25 dB gain switch on the RCA in. Purchased from amazon, Australia. Delivery was quick from opposite side of the large island. The amazon box was a great efficient fit for the 2x amp packages.
The 48v 5A supplies are the same in each box, seem quality enough, but aren't Fosi branded like the 32V ones i have with V3 Stereo amps purchased early 2024. Here's a blurry low light photo:
I first installed a V3 mono on just one channel, and played music (stereo downmixed to mono signal), with a V3 stereo on one side, and a new V3 mono on the other. with V3 mono gain on 25dB, RCA input, there was still a little gain/volume difference comapred to the V3 Stereo. not unexpected. but it otherwise sounds fine - Most notably, this confirms these have the correct phase. Only one QC sticker exists on the bottom of the amps.
Swapping 32v power supply and the 48v, sounds the same at the volume I had - ~80dB A-weighted, 2m distance from 6" bookshelf speakers, in a smallish 3.5x3.5x2.4m room, Gain/volume is unchanged with different voltage power supply, as expected.
Now I have both of the V3 monos connected with balanced source/input (source is MOTU Ultralite mk5).
With output level from MOTU adjusted, feeding the V3 mono signal strength to match subs, all is well. Which is to say it's the same as it was. I ordered the V3 mono somewhat on an impulse, and for peace of mind of PFFB freq response, and balanced is nice to have.
How can i resist to comment on heat??
early days, and it's not warm in here at present.
Firstly - my existing V3 Stereo, 2 of them, are powering a pair of passive subs, which are probably about 3ohm load each. I'm using just one channel from each of the V3 Stereo. In the past, I had tried 48V on those, and they got a whole lot hotter than with the 32V power supply. Since I am unlikely needing the extra power, I kept using 32v. That was ~18 months ago.
Just now, i put a 48v on one of those 2 V3 Stereos. it got noticeably warmer. it sounded the same (it's one sub of two, not played all that loud - gonna be hard to tell). the other one seemed basically cold to the touch.
The V3 mono, with 32V 5A power supplies had some slight warmth. for a while, have had one of those two mono powered with 48V 5A, the other with 32V 5A. the 48V is perceived as noticeably warmer to the touch, but not by all that much. i don't have any measuring equip. not listening very loud.
With 48v, absolutely not a temperature i would have any concerns about. but with passive cooling, when this room gets warm, it may make a big difference and change that thinking. I am not against perhaps cooling them in the interests of potential enhanced longevity.
I will probably run both mono at 48v for now at least. while under warranty, and through a summer. I'll be turning them off when not in use. don't care about auto standby option for now at least.
I cut the power from from the mains, and heard no concerning sounds, mechanically nor amplified through speakers. same when turning them back on by plugging into mains. i probably won't power on or power off my Motu source with amps powered. Though the thump that makes hasn't been disturbingly loud.
Oh, it does seem like the DC barrel power jack into the amp on one of them at least can fail to deliver power with only a minor disturbance. not a great connection perhaps, but cramming it in fairly firmly and it seems ok.
Amps seem very fine. they do amping. music plays. and i can have placebo of so much magical SINAD, perfect absence of crosstalk and superior balanced connection, and PFFB. veils! nights! days! (not.) It subjectively sounds the same. it sounds fine. it sounds great. it sounds just like it did before with different, adequate amplification.
I did that Kippel Distortion listening test.
https://www.klippel.de/listeningtest/ i did the two-tone 70hz 800hz stimulus.
I'm probably pretty mediocre at "listening". good. I hear plenty enough that I don't like in some recordings/productions. I don't need to be hearing more of my equipment.
Your personal audibility threshold for the particular test combination (stimulus and DUT) is
-33 dB!
With volume up a bit towards louder end of what I might sometimes enjoy for a while, playing music, JBL Studio S26 standmount speakers, high-passed at 76hz LR8/48dB octave, I just shoved the mutlimeter on a speaker output of the V3 mono, and saw about 8Volts. presumably i'm not needing that many watts? but quick peaks could well be much higher I guess. But the 32V power supplies would probably be adequate.
Was listening to Pineapple Thief's "Versions of the Truth" earlier - nice sounding recording, with great drummer and great sounding drums.
I also did this, as a crude, perhaps practical test to see whether PFFB was making any freq response difference with those JBL S26:
Right after unboxing one of the V3 mono, I put UMIK-1 in a mic stand nearfield to one speaker. position fixed. A sweep measured with V3 stereo amp.
changed amp to V3 mono, adjusted output of test sweep to make it close to SPL match. Comparison below. (ignore the 23hz difference, as that would surely be real-world noise floor variation - speaker was high passed at 24hz)
i would say that'd be inaudible to me with real music content. maybe even some mic/measurement variation accuracy? though i did do several sweeps and for a fixed amp, the lines generally overlayed better than this, so some confidence that the difference might be "real". I conclude with these speakers, PFFB or change of amp makes very little difference.
