I posed a similar question in the ZA3 thread, but…
Just wanted to report back with something odd. My pair of ZA3s that I gifted to my father after upgrading my chain to V3 Monos, he said the left ZA3 failed first and then the other one eventually went, after he attempted to hook his REL subwoofer up to them via high (speaker) level connection. He is returning the two seemingly dead amplifiers to me to check them out, but they don’t arrive until Monday. For now, he has begun rearranging his chain to utilize the low/line-level input for his subwoofer instead by hooking it up to the second output on his preamp.
Has anyone had an opportunity to or succeed with hooking up a subwoofer via high level connection to a pair of V3 Monos? If so, which wires did you run to which speaker jacks on which channel/amp?
Or is there a technical reason why this is a massive no-no, maybe due to how monoblocs are laid out in general?
-Ed
As
@MCH said, hopefully the ZA3's have just cut out.
I have experience with older RELs, and I run two more recent MJ Acoustics 50Pro ii's.
The warning for the MJAcoustics is:
"If you are going to connect both high level and LFE inputs at the same time please make sure that your Stereo or AV amplifier does not have a 'Digital Output Stage' or is wired in 'BTL' (Bridge Tied Load) mode"
An additional interface module was available to handle this, and the warning went on to say this could damage either the source amplifier or subwoofer amplifier or both.
If you look up REL's information on this on the internet - there is a YouTube video ... their advice is completely different.
Their's is to connect the high level signal as usual to your subwoofers, and use the RCA for earthing at the same time, with the RCA volume switched down. So it would be interesting to know if your father had both (line and high level) or just high level connected.
I made the error with my first single MJ Acoustics by following the REL advice!! But I had no volume up on the 'earthing' RCA on the subwoofer. At any rate everything survived with an Aiyima A07 (and indeed and Allo Volt D).
I also ran a summed RCA for a while on it's own into a single MJ Acoustics.
Most recently I ran high level happily into both MJ Acoustics... making sure no RCA connected at the same time ... but not yet on the V3 Monos...
There needs to be much more publicity from amp and sub manufacturers about this. Or sub manufacturers need to stop connecting one of the inputs to ground, and use a diff amp on the high level connections.
EDIT: I've just checked an up to date manual for my sub. This note is added. It is possible your sub manufacture may have a similar isoltator option - or you can probably use the one from BK electronics. ...
In both cases the isolators are very expensive (or were) - at the time I think £200.00 plus plus ...
BK seem to be putting the emphasis on the amp supplier (in this case Fosi) to say if high level is possible.
I agree: It sure would be interesting to know if
@Fosi Audio have protection cut outs on their v3 Monos.
