Freshman1966
- Joined
- Apr 20, 2022
- Messages
- 14
- Likes
- 14
Oh thank heavens, a user impression on a user impressions thread! I think you should install all, and make sure you are not mixing and matching any op amps and then compare with your Atoll.
I genuinely don't think that swapping one is going to be viable (make much of a difference ... I do not understand any benefit to mixing op amp types in a parallel circuit but anyone please correct me if I am wrong) But it is very good that you have the Atolls as a yardstick.
On a serious note, if you have a 3db variation between your monos, then this is serious and Fosi need to replace that.
Please would you verify this? 3db is clearly audible as a balance shift and would shift where instruments and voices might appear in the soundstage.
Many people will be using these without Dsp
Post edit: balance variation db with all same op amps![]()
About the "gain problem" I mentioned - I cannot really explain it but it seems not to be a problem of the amps. I do have an imbalance in my room and especially when all DSP is off, I need to apply some kind of balance (through DSP, since I don't have any other means). With the monos I need to apply a 3 db higher correction as with the Atoll - you're welcome to explain where that comes from.
OK, I had actually already decided to pass the Monos on, but in the end courisosity got the better of me. So I put in the second pair of Sparkos op amps....
And now, you can beat me, but I really cannot tell which one is which, anymore. I chose three tracks which do not cover everyone's tastes but include many of the elements I appreciate:
- Boz Scaggs, Thanks To You
- Anette Askvik, Liberty
- Gregory Porter, It's Probably Me
Now, what do I do? Keep them or stay with the Atoll... For once, my wife has an opinion about Hifi - "the big silver thing looks much prettier". I guess, I keep both for a while.
Cheers
Stefan
@SMen Absolutely...1966 was a very good year, indeed
