I see this mentioned often, but from a purely technical standpoint, I don’t understand it. I think it’s a myth that you absolutely must have balanced wiring to achieve the best possible sound quality.
Balanced in-and outputs use two signal wires in opposite phases (hot and cold) plus ground. Interference typically couples equally to both conductors and is largely eliminated in the differential input through subtraction (common-mode rejection). The practical benefit therefore lies primarily in the suppression of hum and crosstalk, as well as in the ability to use very long cable runs with minimal interference.
In a typical home setup with short connections of about one meter using RCA (Cinch) cables, however, this advantage is usually hardly relevant. Amir’s Amazon Basic RCA cable set pretty much settles the issue of connectivity. With properly built equipment (which is, of course, a basic requirement) and reasonable cabling, interference rarely occurs to a degree that a balanced connection would audibly improve the sound. Accordingly, there are normally no sonic advantages over unbalanced connections, and there is no advantage over digital connections anyway, since the signal is not transmitted analogically there.
In practice, balanced connections are therefore truly useful and relevant primarily in studio and PA environments with long cable runs and complex setups, because interference is much more likely to occur there. In classic home audio applications, they are often more of a convenience or safety measure than a pure necessity, and in my opinion, their importance is completely overrated.
