FOSI S3 Balanced Streamer Review
Rate this streamer
    Votes: 3 1.3%
    Votes: 19 7.9%
    Votes: 90 37.5%
    Votes: 128 53.3%
Again let me say.. if you are using the analog out of the S3 at 100% the signal is hot. You may need to pad the input of your pre amp or amp. How do you know you are not overdriving the input?
I wouldn't really call them "hot" since they are standard 2V for RCA and 4V for XLR at 100% volume (as seen in Amir's review). Most preamps have more than enough headroom for that.
ok not hot, stout;)
How do you know you are not overdriving the input? Is it metered? Not the final output but the input stage.
I am going to do more tests on my set up, I currently have 12 db pads on the output of my S3 into my mixer. Input meters still dance pretty well.
My issue is needing a Hdmi Arc to connect the tv to the amp. My tv only has one optical and I'm already using that one with the Fosi K7 headphone amp. That's why I'm looking at either this unit or maybe the Wiim Ultra for the HDMI Arc.
You could use a toslink splitter or switch to connect the TV to multiple downstream devices.
ok not hot, stout;)
My pre has 9.8v-10.3v input sensitivity on low gain, so there's plenty of headroom for the Fosi
Replaced my 12dB pad cables with straight through..input from S3 with output set at 100% is lighting all input Leds all the way to -2 but not the OL Led. When you're at -2dB from 0dbFS it makes it hard to add EQ, reverb..etc. I'm going to go back to the -12db cables. I am going into a Presonus digital mixer.
YMMV
That topping A70 Pro is a non typical device, no? A pre amp with no gain?
Ok I was referring to at some settings it has no gain which enables it to accept a very large input voltage. I think @formdissolve uses it this way. 0dB gain, 100% feedback allows large input voltage swings. At high gain input is limited to 2V.
We are developing an All in One Streaming Media amplifier. What are your expectations for this product? Feel free to leave me a message about anything including price, screen size, functions, appearance, interfaces and so on, and we will try our best to incorporate them into the product design.
Fosi is doing great work! I think the latest version of the S3 app works very well, the EQ is the one aspect that needs a bit of refinement.
Thanks,In the latest version, which is 0.0274, we have upgraded the EQ, so the changes will be more noticeable. You can test it out and check. Thank you for your feedback.
Is it a PEQ or GEC? How many bands?:oops:
Is this new version the long-awaited version that fixes support for the Fosi VOL20 Bluetooth volume control?
Thanks,Currently, these two devices cannot communicate with each other for the time being due to inconsistent Bluetooth protocols.
very loud popping noise when using hdmi arc input connected to Genelec 8020D over xlr. The popping occurs very frequently and happens everytime on TV startup and when starting videos after a brief period of inactivity. The pop is very loud. The popping makes the S3 unusable basically. I am running latest firmware.
TV ARC only or eARC compatible?
