Thanks,You can use Google Home. I’ll send you the networking video privately — it was recorded during our internal testing, just take a look.so I can google cast to either/or S3 or S3 Lite but not to a group created in Google Home? This blows.
Thanks,Regarding the third question, yes, operations such as firmware updates can be completed via the APP;I revisited the entire thread and believe that this answers my first question…
Thanks CptKaos and CrankyFrank!
@yuting - can you answer my question 3 above?
Thanks,Why do you want USB-C? USB-A can already support a sampling rate of 768 KHz at present; also, why do you prefer it to be USB-powered?It's a bit more expensive than I expected and why is it USB-A out rather than USB-C? Bonkers. Also surely it could have been USB powered? And no parametric EQ?
USB-C is the new standard. Why would people want an old connector on a new product? USB power would make it far easier than having a dedicated cable and power supply for the product.Thanks,Why do you want USB-C? USB-A can already support a sampling rate of 768 KHz at present; also, why do you prefer it to be USB-powered?
Well if you're streaming hi-res that's not particularly surprising.A small but potentially useful observation: streaming over Wi-Fi through the Fosi Audio S3 seems to be less reliable than using a wired LAN connection, even though I have a very stable Wi-Fi signal throughout my house.
I occasionally experienced connection stability issues and dropouts while using Qobuz over Wi-Fi. The problem disappeared completely after I switched to Ethernet. No more dropouts.
I stream high res all the time on Wi-Fi with zero issues, even after hours on end.Well if you're streaming hi-res that's not particularly surprising.
Zero dropouts here, but I use Spotify Connect.I stream high res all the time on Wi-Fi with zero issues, even after hours on end.
I would guess it reflects the highish core price of buying in the streamer engine common to both.I was able to try out the S3 Lite thanks to the Amazon Vine program. Its price is incredibly close to that of the standard S3, which, however, offers a myriad of additional features. Honestly, I don't understand the positioning of this product; it offers less than a WiiM Mini (lacking even an analog output) and costs only 50 euros less than the S3.
I can't disagree with this. It's a nice looking unit (in black, finally) but if buying myself, would not pick it over the main S3, which has a perfectly good DAC in it. The app has improved but I am still using my WiiM Mini for my garage system, and that little puck continues to impress me, plus their app is very, very good. It is pulling signal in my garage 40' away from my upstairs router in a house made of brick (does have some windows on that side to garage, I assume that is what allows the signal to get that far).I was able to try out the S3 Lite thanks to the Amazon Vine program. Its price is incredibly close to that of the standard S3, which, however, offers a myriad of additional features. Honestly, I don't understand the positioning of this product; it offers less than a WiiM Mini (lacking even an analog output) and costs only 50 euros less than the S3.
At the very least, it’s pleasing and has almost identical dimensions to the Merak, so I can use it for a small secondary system.I can't disagree with this. It's a nice looking unit (in black, finally) but if buying myself, would not pick it over the main S3, which has a perfectly good DAC in it. The app has improved but I am still using my WiiM Mini for my garage system, and that little puck continues to impress me, plus their app is very, very good. It is pulling signal in my garage 40' away from my upstairs router in a house made of brick (does have some windows on that side to garage, I assume that is what allows the signal to get that far).
Fosi continues to expand their product range, definitely not trying to specialize but to put a lot of stuff out there. I feel also they are adjusting their price points upward over time, the BT20A MAX is good but a bit expensive for what it offers. The original V3 Stereo amp, the Q6 DAC and the P4 preamp are all really good sub-$100 values, as is the Box X5 phono pre. The S3 prices are I think carefully calculated to be competitive with WiiM, but still make a pretty good margin.
I am looking forward to their new DAP player, that could be a good product for them, depending on price. I have been wanting something that uses the Apple wheel system with decent storage and easy file transfer. Mostly for car use.
Because they are more reliable long term. USB prongs and ports get damaged more easily.USB-C is the new standard. Why would people want an old connector on a new product? USB power would make it far easier than having a dedicated cable and power supply for the product.
This has no basis. USB-C are used on the most demanding connections like smartphones and tablets which can be connected and disconnected multiple times a day. USB-A and B are not. So I'd like to see your evidence.Because they are more reliable long term. USB prongs and ports get damaged more easily.
You're a charmer. This is both common sense and widely known.This has no basis. USB-C are used on the most demanding connections like smartphones and tablets which can be connected and disconnected multiple times a day. USB-A and B are not. So I'd like to see your evidence.
"Common sense" - great argument.You're a charmer. This is both common sense and widely known.
Thanks,Thank you for your sincere advice.I can't disagree with this. It's a nice looking unit (in black, finally) but if buying myself, would not pick it over the main S3, which has a perfectly good DAC in it. The app has improved but I am still using my WiiM Mini for my garage system, and that little puck continues to impress me, plus their app is very, very good. It is pulling signal in my garage 40' away from my upstairs router in a house made of brick (does have some windows on that side to garage, I assume that is what allows the signal to get that far).
