FOSI S3 Balanced Streamer Review
Rate this streamer
    Votes: 3 1.3%
    Votes: 19 8.2%
    Votes: 86 37.2%
    Votes: 123 53.2%
Hang in there.
TY I certainly hope this will get ironed out. Strange that some have no problem while others like me do. Is it possible that there is some obscure setting in my wireless routers that causes this? I get Windows updates through the same network frequently. I tried wired as well but that goes through the first wireless router as well.
Can you hop on ur pc ping the address and log in that way or maybe a teamviewer session with fosi and force the update that way.
Yes I have tried to update via my laptop logged into the devices web interface (correct terminology?) and get same result
and here it be....
So what version do you have now? I still cannot update manually.
Are you hooked up wireless or wired?
I will check when I get home today. I know it updated because I have the 10-band eq. It connects wirelessly as it’s on a lower floor than our router.
Hehe:)
Another peculiarity I've discovered with using the S3. I'm listening in a near-field setup, and all my gear stays on and often goes to sleep due to some degree of inactivity. Some things wake up properly and recover with no issue, or me having to take action. I use roon with my music library on a NAS. Network --> TransportPi --> S3 (Opt-IN) --> Preamp --> Vibelink amp. I often will pause roon playback and do something else away from NF listening desk. When I get back, I press play on my roon remote(software) and nothing. Roon shows the track playing, but nothing is coming from my amp.
I've learned this behavior has to do with how the S3 auto-detects a signal on the input. In particular, the HDMI/Opt input. The S3 shares the electrical connection internally between the HDMI port and the Opt port. Under normal listening I have to press the HDMI/Opt button on the front panel twice. The 2nd press switches the input from the HDMI(default) to the Optical. Very odd action, but it works - most of the time. However, after the S3 'falls to sleep' due to signal inactivity, and I start my roon track playing again I hear nothing... because, when the HDMI/Opt port wakes up and senses my track playing once again it, wait for it....defaults to the HDMI port and not the optical port. The only fix I know of, is to cycle through the inputs(like normal), and then press the HDMI/Opt button twice to get it switched back to optical and finally get the music playing.
This is not a big deal, but I thought I would share in case someone else has runs up against a similar sequence of events and can't get their music back. Maybe this is a built-in feature and not a bug!
mine says host FOSI-S3_0.53 and Release 0.0.2000x7146fe2. Host version is set by the firmware version? it's all Greek(geek) to me.
My unit shows host description as Fosi-s3_0.57 and release as “not approved.”
And now has Qobuz Connect as a Music Services option?
me too...finally after leaving it and my wireless router on for 2 and half or 3 days. Thank you Fosi @yuting .
Sorry one and all for being such a PITA...but this should not have been this hard. @amirm
my S3 found the update today also but I had to install the update manually.
everybody is finding the firmware cuz Fosi made it findable:p
and now I am a member of the "not approved" club:)
inside joke maybe?...when the FW update that allows Qobuz Connect is installed on the S3 and you look at the unit with Fosi App the Firmware Version says "not approved".
Well that has been you case this whole.time so not much has changed.
Enjoy.
No, before the Qobuz update the FW version was "0.0.200" not "not approved"
