I bought a Fosi MO-3 Monaural switchable Sub/Full Range amplifier based on the TPA3255D2 chip, planning to use it for my new center channel until my Ghent/ICEpower amp case and module arrive - and keeping it for a backup since I live in a remote area of Panama where things take 7-10 day to arrive from the U.S.
Seeing the L+R inputs in the photos before I bought it, I assumed that the amp sums the channels internally and that I could simply use the right channel RCA input for mono. I checked the manual - nothing there. Then I went to the Q&A at Amazon, and the the seller - Fosi - says that you must use two channels of input - using a Y-cable if necessary - even though it is a monaural amp with a single speaker output!
Does that even make sense?
Should I go ahead and just connect my center channel output to the Right channel RCA Input and leave the left input empty? (I bought an XLR>RCA cable just for this application.)
