Fosi Merak Review (CD Player)
Rate this CD Player
  • Terrible (*)
    Votes: 1 0.8%
  • Mediocre (**)
    Votes: 14 11.2%
  • Good (***)
    Votes: 60 48.0%
  • Excellent (****)
    Votes: 50 40.0%
I purchased the Merak after reading this thread.
The sound quality using its Toslink output is remarkable. Cristal clear sound - for me this is a game changer over file playback/streaming and the few other CD transports I have used (Shanling, and a vintage Sony).
I briefly compared the same CD with its ripped file (ripped with the Merak) played back through an attached USB drive. USB playback does not have the magic of CD playback, IMO.
I have not yet checked playback of CD-R, but intend to.
I use it connected to my ECDesigns powerDAC-SX.
I am powering the Merak with an LHY 5v battery power supply which I previously owned, and have not yet tried it with other 5v supplies to see if the power quality makes any difference…
Another great review!
My CD's are mostly early or first releases Vertigo/Polygram or Japanese Sony/CBS. Am I right in thinking the Merak isn't a suitable choice for me given it can't decode the pre-emphasis?
Thanks!
I got one last week to use as a transport and sit right next to my technics sl-d1. It's really nice also it is gapless and haven't had any fail reading CDs yet but if you own the topping e30 beware: signal locks but no sound unless you mute/unmute the dac... Same when skipping track or select any track with the remote. I've contacted support and they said they forwarded the report to the dev team.. anyway, it's a bit frustrating with the e30 but no regrets. . Reading other reports it seems it works fine with other DACs
Hi,
For anyone with an android phone which has a ir blaster there's an app called "irplus". You can actually create "virtual" remote controls to use your phone as a remote or just have it as a backup in case the original remote breaks.
So with the help of an Arduino board and ir sensor I copied the Fosi Merak's remote codes and then created an .irplus file (AI also helped a lot) . The file is ready to import in your irplus app on your phone and it works like a charm! So we don't have to worry if we ever lose the remote or it breaks.
Thought it would be nice to share.
P.S I had to put it inside a .zip container to upload it here. You just unzip it before use..
Old lurker here, it's my first post so I hope I'm not making too many mistakes :-)
I am quite interested in this CD player, as a low cost way to play my CD collection on my Bluetooth speaker (Edifier D12).
I would like to make a complaint, though: why use a 3.5mm jack for the LINE output instead of RCA? These jacks, sooner or later tend to become loose and cause all kinds of trouble. Is there a similar product which offers RCA connection? That would make easier connecting it to my Yamaha AX-570 amplifier, instead of being forced to go through a DAC.
Space is the issue, I guess. For RCA connectors, the case would need to be wider.
Maybe stack the RCA connectors vertically, if the box dimensions are so much of a problem?
I looked at the SMSL PL150 thread and I was scared of the reported QC problems. On paper, it was almost ideal. Oh well...
Exactly. On paper, the PL150 looked pretty much ideal, but on paper is one thing and in the real world another.
My own experience confirms it's a total lemon, unfortunately. With all those QC issues being reported, it's a real bummer.
Such a shame when a product ticks nearly all the right boxes on paper, only to fall flat where it really counts.
The entire SMSL PL line is junk
