JohnnyAudio
- Joined
- Feb 17, 2024
- Messages
- 786
- Likes
- 748
I have a dual voice coil sub. If I use 2 amps, one for each voice coil, do I get more DB from the speaker?
Could you have purchased the G2 rather than the G2 PRO?Thanks for the review!
I just got the Nobsound/Douk version.
The board layout is noticably different and, most importantly, the main capacitors are rated for 25V and the provided power supply is 19V 5A.
You can't use a beefier power supply with this one.
Even though it is cheaper, I'll return the Douk and get a Fosi.
Cheers
Yes, you're right. I didn't even imagine that they could sell 2 slightly different models (!).Could you have purchased the G2 rather than the G2 PRO?
I'M getting my Nobsound G2 Pro today. It was on sale at Amazon for aboutYes, you're right. I didn't even imagine that they could sell 2 slightly different models (!).
Could anyone confirm that the Nobsound G2 Pro is exactly the same as the Fosi tested here (modulo the gain switches)?
Thanks.
I'll wait for your input then.I'M getting my Nobsound G2 Pro today. It was on sale at Amazon for about
$68.
I guess the weather has been a factor as I still haven't received the Nobsound from Amazon. I see that the Aiyama is available at Ali Express for about $54 (including shipping) with the 32 volt PS.I'll wait for your input then.
I got my Nobsound yesterday and the only differences among the 3 that I can see are the gain switches which are very accessible at the bottom of the unit and (from the manual) low pass ranges from 40-300 Hz. Also, the bass frequency and volume control knobs are click-type making it easier to regain your setting if accidentally changed. I'm using the unit to replace the subwoofer amp (which failed) in my Def Tech STS loudspeaker. I re-wired the STS making it a fully passive speaker and am using REW to finesse the Nobsound settings.I'll wait for your input then.
Make sure that it's not the JUNIOR Aiyima.Following your advice, I bought the Aiyima which was significantly cheaper on AE with the 36V PSU than the Nobsound one (~50 vs 75€). Actually, I may just use the board in my velodyne CHTR sub, since the high-pass line output still seems to work (the power amp of the board is dead). My only problem will be to find a way to put the Aiyima board on the heatsink of the sub.
do you think one of these Amplifier is good to move a subwoofer Ciare CS253 (200w RMS 2ohm, but it can play also at 100w RMS 4ohm). Thank you.
When the signal amplitude was high enough at a low-impedance frequency spot then the sub would have drawn too much current and put the amp into protection. With the 19V supply the current would have been limited by the supply voltage, so instead of triggering protection, the output would have just been clipped.1) Can anyone share some knowledge about why the Nobsound G2 Pro entered protection mode with the Boston 4Ω 10" driver and the 32V and 48V power supplies, but not with the 19V one?
2) Why did the Nobsound make the Vifa driver distort so much with those thumping loud sounds when used with the 32V and 48V power supplies?
3) I have set the crossover on my AVR at 80Hz for the subwoofer out. Why the crossover knob on the Nobsound makes a seriously audible difference even when turned more than the middle (which is apparently already higher than 80Hz at the middle position?
4) Any solutions for finetuning the EQ settings for this frequency range (say 20-120Hz) to somehow "voice" the Nobsound to my liking (except the AVR's EQ) ?
Thank you so much for the reply!When the signal amplitude was high enough at a low-impedance frequency spot then the sub would have drawn too much current and put the amp into protection. With the 19V supply the current would have been limited by the supply voltage, so instead of triggering protection, the output would have just been clipped.
With the 32V and 48V supplies the amp likely delivered more power than the subwoofer could handle.
The Nobsound's crossover is not very steep, but rather a gentle slope.
Yes, measure the frequency response with REW and design a filter to flatten it. Use that filter with your music player or EQ software. Alternatively (what I'm doing), let Dirac take care of bass EQ.
