Fosi DS3 Portable DAC & HP Amp
Rate this portable DAC & HP Amp:
    Votes: 7 4.7%
    Votes: 18 12.2%
    Votes: 53 35.8%
    Votes: 70 47.3%
found a few things with it
Thank you @L-Train , issues are obvious and I dont like the policy to test it on users. And for sure I do not like that you reported it in April/May to Fosi Audio, now it's September, and still no fix... @Sensi , that is what you call customer care system?
I am quite happy user of DS2, but overall I find TRN Black Pearl better device. Black Pearl measures the same as DS2, it has PEQ, DRE implementation issue solved, no fade in effects and channels imbalance, and it costs ~50$. ASR users also made software for windows where you can change filters and amp mode (AB or H), if you want.
Fosi Audio - DS1 was good, but DS2 and DS3 brought many questions, and I do not understand why every question about issues end only with "we will try to figure this out"...And after that - nothing happens. But you still sell a lot - good for you!
will you review the similarly priced schiit vestri dongle dac ? thanks
we have been given a budget dongle dac with a ES9039Q2M, no DRE here.
I managed to grab Aiyima H3 on ES9039Q2M for $30 when they were available. There is now the H4 with display for around $99 unfortunately. Link to pic of the chip in H3 below
That reminds me thought, don't ESS chips also have their own DRE, just turned off by default due to glitches it caused? Wonder how those glitches looked like in measurements.
Am I the only one surprised that the Fosi DS3 received a golfing Panther despite the rather absurd amount of distortion on the balanced output? I’ve seen products get completely trashed in reviews here for way less than that.
I agree, not on the panther specifically, but on the general reception. I was somewhat forgiving of Fosi when it came to non-transparent K5 Pro (and likely Q4), didn't initially mind the controversy with fake user reviews which got Fosi banned on HeadphonesAdvice, but didn't appreciate them naming products to fool customers into buying theirs by mistake (K5 Pro, K7), and after I've made ass out of myself for recommending DS2 in the past (I took time to write apologies to every person I could find and edit my posts on reddit...), I'm kind of wary of any issues with their products. Given the measured issue, and the post about quirks like DC offset and reverse polarity, I don't think I will be mentioning DS3 to anyone, and I might warn them instead if they ask about it.
And seeing arguments like "it is for mobiles" or "it was made for IEMs", "it is fine as long as impedance is low", "it is fine as long as you don't use balanced"... like WTF? It is a dongle DAC with advertised features, you buy it, it has to work. Even if you buy it for low impedance 3.5mm IEMs, it does not mean you won't change headphones in the future, then what? And in a $99 product no less. There are cheaper dongles without such issues.
Would like to know why someone would rate this thing "poor".
I did, I initially rated it "not terrible" given all the included functionality someone might prioritize over performance issues dependent on headphones and listening level, but after considering $99 price, I decided to lower it. I simply find it not acceptable for the price. I would take even a -15dB hit to SiNAD at full output rather than wonder if I'm dipping to below $3 dongle range at a level I'm using.
If panthers and recommendation are amirm's and are subjective, then by all means the rating vote is subjective for every ASR user.
As I just responded, it seems to be an issue with high impedance loads/headphones. So if you have a planar like I do, you won't hit.
Otherwise, I have not seen this impairment before so don't have any insight into it.
I have my DS3 permanently connected to a 3e Audio A7 speaker amplifier via XLR. With pleasing results so far...
So "even" better to change connection to RCA - or just stick with XLR? ...So is it likely inside or outside the "flawed" zone of operation I'm running the DS3 in load-wise?
I'm not certain - but I guess it's a low impedance load(?) I'm way more certain that's a straightforwardly to answer question by @Roland68 based on his profound knowledge, maybe @amirm or you guys following this thread might like to answer. Huge thanks!
Did some testing and found the the phase gets very twisted when the EQ is enabled:
This is the Moondrop FreeDSP in green and the Fosi DS3 in red.
@Sensi Maybe something to put in the backlog?
Thanks for sharing.
The PEQ thing definitively at least in theory requires further investigation when it comes to degradation of output signal quality!
If it turns out to better keep on using Equalizer APO rather than "ruining" signal by device's own PEQ, that would undermine the whole benefit of having that integrated into hardware ...which otherwise is one pretty damn awesome feature to have at hand!
...'Waiting impatiently for a new desktop DAC release by Fosi Audio featuring all these DS3 capabilities...
Anyway, keeping in mind limited testing capacity, that could be too much asked for, measuring devices over and over again within an almost endless range of different EQ settings possible.
I concur on this note. Having 32 band of EQ is a godsend, but it needs to work correctly of course for being a blessing in the end.
That's just a side effect of inverted polarity. The graph jumps to the other side when it crosses 180. if you inverted the polarity the graph would follow the green trace perfectly.
Ah, ofc! That makes total sense.
Another see, it can be done.
Once everything mentioned in this thread has been ironed out this kind of PEQ functionality would be a godsend in an affordable multichannel DAC or even external DSP device.
Very impressive to see in a relatively cheap consumer product.
For my IEM's a 10 band PEQ is enough, although more is always welcome!
But for speakers, a 32 band PEQ would let me correct both speaker and speaker/room interaction directly in a DAC that I can feed any signal directly.
Would truly be a gamechanger.
At this point this seems the only thing that is not yet been "solved" at reasonable cost.
If such a product already exist I am not aware of it.
Thanks for the feedback. We're developing new firmware to improve it. I'll share it with you once it's done!
There is a new V1.6.10 firmware for the DS3 on Fosi's site that appears to have targeted the issues I brought up. I updated my unit and gave it a quick test:
1. There is still DC offset after USB is initially plugged in, but goes away (and appears to remain gone) once audio is played
The automute that seems to be causing the DC offset isn't disabled at start up, or perhaps is left enabled at start up to thwart turn-on thumps or similar.
2. DC offset returns briefly when USB is unplugged
3. 3.5mm output polarity has been fixed
Channel 2 is offset in the oscilloscope display to show that the polarity of both channels has been corrected.
4. Frequency response when upsampling is enabled has been fixed
The frequency response difference compared to having upsampling disabled is negligible.
44.1 kHz
48 kHz
@Sensi , thank you very much for listening and for having a quick turnaround with this new firmware. It's support like this that goes a long way with the community. Hopefully the new issues #1 and #2 I brought up above can be resolved.
Excellent review @amirm . Was the IMD graph done at low gain (it says "Log Gain" in the graph)? If you still have the DS3 can you measure it at high gain?
I've had my DS3 for a while now and found a few things with it, particularly:
1. DC offset at the 3.5mm output when no audio is playing
When no audio is playing the 3.5mm output has quite a large DC offset depending on the load impedance. Here's an annotated picture of a measurement with my Rigol DS1054Z oscilloscope. The DS3 was measured in high gain mode with volume at max.
I also measured it with my Fluke 189 multimeter with lower load impedances:
Load impedanceLeft (volts DC)Right (volts DC)
10k0.03860.0356
47k0.12750.1163
100k0.24250.2221
Unloaded with Rigol 1054Z (1M)~1.8~1.6
Unloaded with Fluke 189 (10M)5.14404.6214
If connected to a DC-coupled amplifier that has a high input impedance this may trigger DC protection circuitry or even worse send it right through to the load. In practice I don't think there are many amps that don't have AC coupling capacitors on their unbalanced inputs or some sort of DC protection so it's probably not an issue for the vast majority of users.
@Sensi I sent this issue to Fosi Support back on April 7th and they replied that they had forwarded it to your engineering team. I've since updated to the 1.6.5 firmware that was briefly available and the DC offset is still there. I believe this may have to do with power saving features? Since the DC offset is 0V when silence is playing, perhaps this can be fixed by setting the XMOS streaming mode to "Always On" in firmware (so that it's fixed with all host devices), or expose the Streaming option in the Windows driver (so that it can at least be toggled on Windows machines), or if possible even have it as a "Power Saving" toggle on the Fosi Audio Audio Control Center web UI.
2. 3.5mm output inverts polarity
The 3.5mm output appears to invert polarity. Whether this is audible is up for debate but I believe preserving polarity is preferred.
@Sensi I reported this to Fosi Support on March 11th and received acknowledgement but wasn't told if it was sent to engineering. The ES9039Q2M has a DAC_INVERT register that should be able to fix this:
If inverting the 3.5mm output to correct polarity unintentionally inverts the balanced output (i.e. the balanced and unbalanced outputs have opposite polarity at the hardware level), perhaps a toggle on the web UI to invert the DAC output would be a good idea. This would give the user flexibility based on the output they use most.
3. Non-flat frequency response when upsampling is enabled
When upsampling is enabled on the web UI the frequency response of the DS3 drops about -3 dB at 20 kHz:
44.1 kHz sample rate
48 kHz sample rate
@Sensi I sent this to Fosi Support on May 11th but didn't receive acknowledgement. I tested it again with the 1.6.5 firmware and the issue still remains.
Other than these issues/quirks the DS3 sounds damn good with my Truthear Zero REDs. It's definitely an upgrade over the Apple dongle I was using previously.
We just upgraded the firmware to solve the issue. You can try to upgrade your DS3's firmware with this:
I did let my AI loose on the Fosi DS3 to verify the EQ; and it found a bug:
On firmware 1.6.10, when the playback sample rate changes, the DS3 recalculates only the first 8 PEQ bands. Bands 9–32 keep filters calculated for the previous rate until the EQ is switched off and on. With my 32-band preset, uploaded while the DS3 ran at 44.1 kHz and then played at 48 kHz, the response was off by up to −6.2 dB at 13 kHz.
@Sensi ^^
