Firulais71
- Joined
- Dec 24, 2025
- Messages
- 47
- Likes
- 32
Good morning everyone.
Motivated by your highly informative comments and posts, as well as the very detailed analyses by admin Amiir, I've decided to buy the following components for my secondary listening room/TV room:
- Fosi V3 mono amplifier + 48V 10A power supply.
- Fosi ZD3 dac.
- Fosi ZP3 preamp.
- XLR cables for connecting the dac to the preamp and amplifiers.
I'm going to cool the amplifiers with fans at the top and bottom of each monoblock.
The total price for the product bundle, including shipping to Peru, is $750.
The set will be used to power a pair of 3-way tower speakers with 8 ohms and 94 dB sensitivity, to be installed in a semi-treated listening room of 25 m². All my music is digital, from Tidal, as well as thousands of flac files, some are rips from my old cd´s, and many dsd files that I will play from a pc connected to the dac via usb cable.
That said, ¿do you consider this Fosi component bundle adequate, or would you recommend making any changes/upgrades, perhaps looking for a better dac or preamp? As I mentioned, the investment is only $750, a real bargain, so I'm willing to spend another $300 or $400 to upgrade another component if necessary.
Best regards.
- Fosi ZD3 dac.
- Fosi ZP3 preamp.
Best regards.
