Fosi BT20a Max
somehow I missed this thread :D Here's my review, I mostly agree with other review so far.
Mine's out for delivery today. After the BT20A pro, needed something with a remote for the home office room, which was the primary driver so I can leave the phone alone.
I did do the Op-Amp switch to Burson Audio V7 on the BT20A pro so should make for a good A/B test between the two.
A new package has arrived from Fosi audio. Let's see what has arrived. This is their latest desktop compact amplifier, the BT20a Max, which arrived to me before the New Year. But I tested it long and hard. It was supposed to be introduced at the end of 2025, but the final date has been postponed to January 10, 2026. The price ranges from 280-320 USD ( - sale %), depending on the power supply output (32v 5a - 48v 5a and 48v 5a Gan), but as is usual with Fosi promotions, I see an introductory 20% sale on their website. This price may vary. At the time of writing this article, this is the price I saw on the official website.
Let's not wait any longer, unpack and see what's in the box:
Contents: BT20A MAX
48v 5a Gan power supply
Remote control
Bluetooth antenna
User manual.
Before we start, let's take a quick look around, front panel:
It's immediately clear that the design is new, obviously I'm mainly thinking of the front panel here. It's different from what we're used to. It has a designer, rounded front panel. With a plastic decorative strip on top. This is the first device with all four edges of the front panel rounded. We find a power button on it, which is also the channel selector. Here we can see that we have 3 input channels. We see a series of LEDs that indicate the currently used input, the remote control sensor, an equalizer and a motorized volume control. The layout is very logical, I like it too.
The device has very good parameters. I don't usually fill my reviews with specifications, I prefer real-world usage reviews. If you want more details, you can find everything on the manufacturer's website. I'll mention a few:
Hi res Bluetooth Audio, With Bluetooth 6.0, the BT20A MAX supports a wide range of high-quality codecs, such as LDAC, aptX and aptX Lossless, Qualcomm chip: QCC3095. PFFB (this is Fosi's first stereo amplifier with PFFB) 2x300 watts on 4Ohm, Hi pass filter, snr 112 pcs. distortion 0.003%. Separate power supply for digital and analog sections. Elna capacitors. Built-in cooling.
Factory data:
The housing is reminiscent of the v3 mono design. We also find the round side ventilation openings. It finally got a top opening where the heated air can escape. This is the MAX inscription itself. We know from physics that the flow of hot air rises upwards. It got a significant help for ventilation: a built-in fan, which is relatively quiet. The ventilation MAX inscription visible on the top of the housing is equipped with a perforated orange insert plate like the side vents. We can hear a discreet rustling (and airflow) from close up during operation. Since I sometimes listen to music very quietly, I hear it, and during the break between two songs can hear, which bothers me. A basicnoise during the break. After a few days of use, I couldn't get used to it, so I took it apart and pulled off the fan's contact lug because it can still ventilate through the slots and checked if it overheats. I don't encourage anyone to do this, but there was no significant heating. After a few hours of use, without active cooling, I measured 33-34 degrees Celsius. I've been using it for two days now without active cooling, with normal room volume, and there is no significant heating. So far, it has never exceeded 34 degrees Celsius. Unfortunately, I haven't measured it with the fan running before, but when I touched it with my hand, the heating was very similar. It may be that the change is only minimal. I don't want to disassemble it again for accurate measurement, I will obviously monitor the temperature in the long term and if necessary, I will restore the active cooling. If I ever notice overheating, and I need to reset the factory cooling. I will report it in the article or in a comment.
I couldn't get used to the sound of the cooling fan.
Many people are reassured by the fact that it has active cooling. It bothers me. We are not all the same...
Backside:
From left to right we find two RCA inputs. Then a bypass button to turn the equalizer on and off. Below that we find a sub output, then the speaker outputs. These are easy to use with your fingers, not too small. They are larger than the v3 banana sockets, the same as the LC30 banana sockets. They are better because they are big enough for your fingers to comfortably reach and tighten well, but unfortunately they do not fully accept the standard banana plugs. Only about half.
AudioQuest SureGrip 100 BFA banana plugs:
They are not deep enough. In any case, the connection is stable. The sockets are not loose. They hold the plugs tightly. I think this may change in the future if possible. It would be nice if they were made of copper and gold plated. These banana jacks are similar on several of their devices. I recommend that in the future we use a jack that accepts standard plugs along their entire length, and is also big enough to comfortably reach and tighten them if we are not using the plugs, but clamps or a fork. Let's move on. Next is the trigger input. There is no output, so further chaining (stitching) with a trigger is not possible. (This is not a problem, because it is not needed at the end of the chain, just an option) Below it we find a high-pass filter switch, which, when using a subwoofer, cuts off the bass from the main output at 80 Hz and sends it to the subwoofer output so that we can use the 2.1 system. Next to it are the bluetooth antenna and the power supply input.
Top vent hole „MAX”
From the external dimensions it is clear that we cannot really pair this amplifier (on top of each other) with any other Fosi product. If it had been a little wider, it would have matched the members of the za/zd/zh series and then there would have been room for a balance button on the front panel, which would be a great help for those listening to music in an asymmetrical room, and perhaps an additional RCA input and a trigger output on the back panel. This is just my imagination. But this way, it would have fit into the family of existing devices with its dimensions. But it was not designed for an existing device family. This is a new device. Used separately, it is a very nice device. It should be treated as such.
Side vent holes:
Motorized volume controll. Well, it is not my favorite. I do not understand what this method, which was widespread in the 90s-2000s, is doing in today's devices. It is not accurate, it never was unless it is very, very subtle, slow. It should be much slower than it is now. In this specific case, it is also disturbing. Because if we use the zd3, zh3 with a fixed output, it overdrives the bt20a max. In practice, this means that the volume control goes from zero to a comfortable listening level in the room too quickly. Usually, physical potentiometers are not accurate in the lowest position. One side often sounds earlier. When we turn the potentiometer a little higher, this normalizes, but that is exactly why a slow and long-travel volume increase would be important. Here, unfortunately, we barely move the volume knob and we reach the normal volume. This is too fast. I encountered the same problem when pairing the p4 preamp and the v3 monos. There, I also reached the listening level too quickly. However, this volume control is completely fine when using CD players, turntables or tape recorders. With a normal 75-85db output signal, the motorized control works well from the remote control. This is a small anomaly caused by the high output signal level in the case of the zd3 and zh3 and of course when using any other company's 110 – 120+db output source, dac or streamer. This can be easily remedied if when pairing the BT20a max with, for example, the ZD3, ZH3 (or other high output sources), they are used in preamp mode. Not on the fixed (full volume level) output. By setting the bt20a max to maximum volume, we adjust the volume on the preamplifier. But this anomaly could have been avoided with a volume control like the long way, very slow, infinite volume control used in the zh3.. For me, this is very annoying.
Usage:
We don't have much trouble with the assembly. We just wind up the antenna, connect the speakers, the sources, the power supply and the fun can start!
Yes, it's fun, because the sound quality is very good! The performance is light, spacious, airy. The stereo space is very good. The Bluetooth connection is stable. The signal processing is good!
The sound is also very good in Bluetooth mode. We get very good detailed sound that is true to the instrument. This is a really good little compact device that will definitely be a success. I wrote my little complaints only because of my habits and my own expectations. You don't have to take it seriously because there are people who will love it for exactly the same reasons I complained about it. It is very important to me and many users that we like the devices. It should have features that we really like in daily use. That's why I write personal reviews and personal expectations about them. Next products should always be better and better..
Controls and connectors:
I usually never use the Bluetooth connection. Regardless, this is a very useful feature. If you need it, it's there. Of course, it provides convenient use, there are those who will love it just because of the bluetooth connection. But I don't play music from my phone at home. I did it just now for the sake of thorough testing. I like to use my reliable cables and my playback devices or the PC player software. During the test, I played many high-resolution files with the full version of the Poweramp application used on my phone. Every detail sounded very good. Whether it was a hi-res or a plain flac file in the phone's player, it was always sufficiently detailed and true to the instrument. The space is very good. It has the same good quality as my v3 monos, and in fact better. Although in the past I have modified my V3 monoblocks with a few extra capacitors, better banana sockets and op amps. In addition, I use them with better quality and double-priced xlr cables than the rca cables of the new comer bt20 max . I don't want to exaggerate the sound again, which is why I compare it to the v3 monoblocks. What can be said about the mono sound quality of the v3 is also here, and even a little better. The Bt20a max provides a very pleasant listening experience. In a home environment, it can easily hold its own in the main hi-fi system. It won't have many other challengers or real competitors in your office thanks to Bluetooth 6 connectivity, two analog inputs and excellent sound quality, as well as its compact size and remote control.. The sound quality is great, very good space, large power reserve which is more than enough for anything. I paired it with large floor-standing speakers. This small amplifier has the power needed to deliver a punchy sound. The equalizer can be turned off, but it does not introduce noise that can be heard by ear into the sound even when used. The equalizer effect is correct. Good remote control. Unfortunately the ZH3 is not one of the devices that can be controlled with a remote control. This would have been really good.
Distortion: 0,003%. Very good! Of course, at high volume, you should not expect the factory-specified distortion value (this varies similarly with all amplifiers) But even this is fine with the BT20a max. At normal volume, its sound is really very nice. There is no noticeable distortion or noise when listening to loud music. It could certainly be measured with measurements, but I didn't hear anything..
Since I already took it apart because of the fan, I also updated the op amps, although the ne5532 is a very good op amp, but I hear it as thin and digital to sound, so since I had many opa1612 and opa1656 and oracle II 02 at home in reserve, I put the opa1612 in it.
Note: The factory ne5532 is in a socket by the way. The possible versions for modifying the op amps are limited because the integrated cooling fan reduces the space, so only normal height I.C. s can fit without removing the entire fan. Since the op amps are under the fan and a little further in, some manual dexterity is required.
I spent days doing a/b testing using the lc30 so that there would not be a momentary pause in listening when switching. I have to say that (I repeat) everything that can be said about the v3 monos in terms of sound quality is also present in the BT20, even the stereo space is slightly better, and I really like my monoblocks and I think the op amps are better in them (akliam LC5). That's why I'm going to get negative comments because according to the measurements there's nothing audible between the op amps. But I feel like these aren't expensive op amps, and some of them I can't hear better because I spent too many dollars on them. Even among the similarly priced ones, there are some that I've thrown away because I liked one and not the other. For example, the opa1656. For me, this sound is not right. That's all for now. Let's skip on this theme..
Another positive observation: The buffer capacitors in the BT20A Max are larger than those built into the V3 Mono.
Inside BT20A MAX:
Summary: Versatile, three-channel compact amplifier with very good sound quality, stable, high-resolution bluetooth 6 connection, two analog inputs and a high-pass filter, as well as a sub output for 2.1 use. With switchable equalizer, built-in cooling, motorized volume control and remote control. Due to its excellent sound quality, it may be a favorite of many users, and may also be popular due to the high-quality Bluetooth connection. Fosi engineers deserve a lot of praise for achieving such sound quality. In the A/B test, I do not hear the advantage of monoblocks. Despite the fact that they were V3 monos powered by a 48V 10A GAN power supply, the BT20A Max 48 V5 A GAN was driven. Neither in sound quality nor in spatial representation. My objections described at the beginning arise from my own habits and expectations. I feel that my small complaints are realistic, but I did not find any fault with the sound quality. Excellent! They have built a serious rival to the V3 mono. Since the sound quality is the same or better in favor of the newcomer, the new amplifier also plus that we have to use a single amplifier, a single power supply, plus there is a volume control, equalizer, and the use of a remote control. High-resolution bluetooth, less heat generated, more inputs, subwoofer output for 2.1. High-pass filter. The overall user experience is high.
Let's enjoy it because it's good.. :
pros:
High-resolution and stable bluetooth connection
Excellent sound quality!
Switchable equalizer
High-pass filter and subwoofer output for 2.1 use.
Good build quality
3 input chanel
High user experience
cons:
The motorized volume control does not work well with a high input signal. It adjusts itself too quickly, the volume control knob reaches the room listening volume with minimal movement. (This is not a fault at all with a lower input signal!)
The remote control does not control the ZH3.
The sound of the cooling and flowing air is too loud for me. Perhaps an even larger ventilation opening on the roof without a built-in fan would have been enough. Or a temperature sensor control to turn on/off the active cooling.
Due to its unique size, it cannot be stacked directly with other Fosi products.
I've been using it for a month now. I liked it. I still think everything as I described it. Unfortunately, an auto on off solution would have been nice. I can't include it in the article. I still have no problem with heating at room volume. And I'm powering it with 48v 10a gan power supply and the fan is turned off. This power supply was for one of my v3 monos. This power supply is not included with the bt20a max.
What do you mean you’re powering it with three supplies? Interchangeably, you mean?
I wouldn’t be surprised at all if the Douk Audio A5 equipped with opa828 would blow it out of the water for clarity and tonal value especially in the low frequencies….if you know the opa828 you will know exactly what I am talking about. Feed that A5 with a Muses 02 based dac and done…just my penny as they say….and nice that they have included this on the same remote as the P4 and ZP3 which are all different looking machines…bit of square there and curve here dear….forward thinking in design would be an attractive quality to grasp and I think HR dept should have their eyes open a little wider….leaving very little breathing space in these designs is adding to the general patina of a ‘throwaway product’ which eventually most seriously people will grow tired of quickly and look elsewhere especially if certain parts can only be replaced with an larger equivalent, it’s an issue I am currently having with an capacitor that arrived with dents. For the sake of 2mm the whole design of the amp is out of sync because the casing is packed so close to the internal caps and board.
Currently some parts that most of these brands maybe NOS which is ok but if that is the case then it would make sense to compensate for replacement parts that are current or at least complimentary in regard to brand quality if jumping from Rubycon to Nichicon for example which in regard to an 63v 3300uf cap there is a 2mm difference in diameter with the closest match. It would not harm the unit using if 5mm clearance was implemented on the edges and top of the unit, just saying….
The opa827 sounds way better than the 828, maybe I got a fake opamp. But the LME 49724 works very well for single channel dual outputs. The Muse03 works but would split it off of the opa1656. The Muses02 works really well with the 1656 when in dual channel DACs, opening up the whole thing without having to EQ for the most part. I would like to hear the BT20AMAX but would want something more than the 5532 to live with it as a clean dynamic source as bad as that is to the 5532 which is really not that bad but I feel there are more musical quality options to go with than the cheap version of every car audio amp produced for unbiased high power for the lowest cost in mind just not to spend a little more for high quality using a low manufacturing cost concept. They could put a little more effort into making an amp that is in between really low budget and half way the cost of a real true to life amplifier just to spend more on some high quality parts for what they are already putting out.
Contents: BT20A MAX
Remote control
Bluetooth antenna
User manual.
Factory data:
Backside:
Top vent hole „MAX”
Side vent holes:
Usage:
Inside BT20A MAX:
pros:
Good build quality
3 input chanel
cons:
New update: I put thermal paste on the junction between the amplifier chip and the device case. The heat transferred has increased. So it's now 38 and 40 celsius (with original 48v 5a gan power). I won't use the built-in fan anymore. But I might remove the side and top grilles to allow air to flow easily. I'm sorry they didn't listen to me when I suggested that the bottom and top of the device have large enough ventilation holes after the v3 mono was released. Then it would be well ventilated according to the laws of physics. The side holes and the top hole are small. The fan's power is also small and its sound is more annoying than its efficiency. It would be good if someone measured how many degrees the was running after a few hours of use with fan, that would be a reference point. (with and without fan) Unfortunately, it still heats up when turned on, even when not in active use. That's why I really miss the auto On/Off function.
I'm not plugging it fan back in anymore. I can't love the fan running.
Amazing how different we all are...I feel no need to modify what Fosi released. Unless I am very close to the fan, it doesn't bother me at all. In the current setup where I'm using it, I'm not close to the amp and can't hear it at all.
That said, I wonder whether Fosi will release anything else with "active cooling." It feels like a bit of a spur track for them.
The BT20a MAX was a new price point for them in stereo amps. We may see more development from them in the $200 - $350 range? But the amp field is getting pretty crowded.
I keep suggesting that they work on something with a volume control that has really great channel matching even at low levels...
I would like someone to measure how much sense this makes, how active cooling is in it. I think its efficiency is very low. I have already completely disassembled it and removed all the decorative grilles. This noise is unacceptable to me. Of course, we are not the same. The hearing threshold and hearing range are different for everyone. Hearing is a strange thing. Many people are also satisfied with the sound of the mc331. I think this is only one Fosi product that is unusable because of the built-in noise canceler. It cuts off the quietest parts of the music and also cuts off the fading ends. And this is perhaps their most beautiful amplifier. But for me, this is a fatal mistake. It would have a nice sound, it is true that it is colored, but it would be quite good. Yet how many people do not even notice it. Unfortunately, it is an irreparable mistake. Well, that is how it is. We are not the same. But there is nothing wrong with that. im hearing ventillator noise 3 meters too in bt20amax. naturaly in silence, not music.
That is notoriously difficult to do as it essentially requires an expensive high tolerance volume control and even then the tracking is never that good at really low levels, or you use a stepped attenuator which is still expensive but means that you end up not being able to set the xeact volume level you want. However there really isn't a problem in these digital days and the solution costs nothing - just reduce the signal level a bit at your source and then turn up the volume control on your amp to compensate, that way you don't get the balance problems caused by having the volume knob set so low.
Yes, the solution is really easy. But when a manufacturer, no matter how much we like it, forces customers to compromise to adapt to the finished product because it still has imperfect functions, it can lead to the loss of the customer. That's why it's important to let them know everything. Don't just accept what you get. It's important to have complete satisfaction from both the seller and the buyer.
Realistically, an amp with a high cost high precision and expensive volume knob doesn't have a place in a budget design. Either get something top end and suitably expensive or perhaps a DAC amp where you can have a perfectly matched digital volume control - the BT20 and anything similar are the wrong products for that requirement.
We've got the Schiit Saga 2 that uses a 64-step relay attenuator, and I love its low-level control and channel matching. They offer that with 4 inputs for $350.
I noticed this week that with certain DACs, the signal is strong enough that the 0 level does not completely mute the music. I checked with Schiit and they said that's normal. Their remote does have a mute function so not a big deal. So far, that's my only gripe. If Schiit can use this type of high quality volume control, seems like the overseas manufacturers could as well. Charge more for it. Make a 2.1 channel integrated with higher grade elements all focused on playback (i.e., with no displays) and sell for $350 or $400.
This level of volume control is mostly helpful with regard to CD/tape/vinyl playback - yeah, with digitial, I can always just fine tune the level from my desktop.
I solved the low volume sensitivity issue by lowering the max input voltage from the Wiim Pro Plus to 85% of max. (1.7V)
It seems to sound better at higher volume as well.
My only issue is a relay “chatter” when I turn it off.
It doesn’t do this in Bluetooth mode so I leave it there when off.
This is a non critical listening area using Elac Uno-Fi 2.0 UB52 nearfield
Edit: Misspelled
Here’s a demo video of the Fosi Audio BT20A MAX featured on my YouTube channel.
Fosi Audio BT20A MAX Description:
In this video, I'll share my experience with the new Fosi Audio BT20A MAX.
I'm not a technician, but simply an enthusiast who wanted to try this amplifier in my home environment to understand how it really sounds.
I listened to it for two weeks, connecting it to my Dali Spektor 1 speakers (in a 2.1 setup with a B&W ASW608 sub) and the massive Indiana Line Utah 5 speakers, to see how it handles different loads.
What we'll cover in this video:
• Feature Analysis: TPA3255 chip and PFFB technology.
• Testing the 80Hz high-pass filter.
• Testing the motorized volume and LDAC Bluetooth.
• My personal opinions on the strengths and weaknesses.
If you like the video, please subscribe to the channel and leave a like to support my future enthusiast reviews!
Some measurements with two different PSUs
Edit: There's also a part 1
Thanks for the links to the BT20A Max frequency and power measurements!
Though now I'm confused. What's the reason for the max to have more premium pricing as a single TPA3255 chip implementation, with ~75-80db SINAD?
*Ok from their marketing materials, I suppose mainly for the additional cooling customization (didn't realize it's active fan), motorized volume pot, remote control and HPF.
