Schlippwhip68
Only one of those boats will win.Maybe solderdude has cracked the code to explain the differences between opamps:
What would convince you that changing op-amps does noting to improve the sound? We have already established that neither measurements nor boats does the trick, so what would it take?Only one of those boats will win.
Why is it so hard for people to accept that some people can hear the difference, envy, jealousy, ignorance, inexperience, physical deficiencies…the mind is quizzically engaged to say the least. Some people believe that measuring a system is absolute to how it sounds. Let me tell you, it’s just isn’t.What would convince you that changing op-amps does noting to improve the sound? We have already established that neither measurements nor boats does the trick, so what would it take?
Why would you need to buy another remote? It looks like it comes with one:Shame it only has an IR remote. Due to physical placement in my room I would need to buy an IR remote control. Something like the BroadLink one I use in another room.
Back of the amp says 32 - 48v power supplies will work. They don't specify what power supply it's going to ship with, I'm guessing will be 48v6a or 48v10a.Just bought the Aiyima 48v 10a power supply for my ZA3. Presumably no issue using it with this amp if I get one?
There are significant costs (much more so recently) associated with shipping and fulfilling larger items. Shipping and storage costs are by volume now, not weight... So without a functional reason for the width it's not surprising they would avoid it.I’m still surprised @Fosi Audio has not made a full width amplifier..
fosiaudio.com
I think you are missing an important part of what I said - 'IR'.
Based on previous experience with things like Topping IR remotes they do not work very well without a good line-of-sight to the device they are trying to control. Of course I'd test it first, but placement of the device in the room might be an issue.
The RC for my Fosi ZD3 manages to bounce off a wall and round a corner without much difficulty, but it’s only about 3 metres away.I think you are missing an important part of what I said - 'IR'.
I'm seeing US$229 (32V), $249 (48V/5A) and $269 (48V/5A GaN). Not sure where you're seeing the higher numbers?So, it's the 10th, should be released today? Edit: It's out
$279.99 to $319.99, 3 options![]()
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp
Delivering up to 300W ×2 peak and 180W ×2 RMS at 4Ω, the amplifier provides ample headroom and dynamic authority. Supporting 2–8Ω speakers and featuring a dedicated subwoofer output, it enables effortless construction of a powerful, well-integrated 2.1 system.fosiaudio.com
Could be because I'm in Europe and the VAT is already part of the price?I'm seeing US$229 (32V), $249 (48V/5A) and $269 (48V/5A GaN). Not sure where you're seeing the higher numbers?
Even with 20% early bird code (MAXSEB20) the net $200 price for the 48V/5A version is relatively pricey by Fosi standards. And this doesn't include any applicable tariffs and broker fees, which aren't prepaid by Fosi for U.S. shipments as far as I can tell?
Agree on it being a touch pricey, especially if you don’t need the high pass or multiple input. Not much reason to get this over the ZA3 for me (or even the V3 Stereo).I'm seeing US$229 (32V), $249 (48V/5A) and $269 (48V/5A GaN). Not sure where you're seeing the higher numbers?
