Fosi BT20A Max Amplifier Review
Rate this amplifier:
    Votes: 2 1.3%
    Votes: 34 21.3%
    Votes: 107 66.9%
    Votes: 17 10.6%
How is the max power at 40hz calculated? Is that where clipping starts or the amp just doesn't put out any more power there?
The power vs distortion graph at 20hz looks like it goes out to 130w?
Thank you for the review @amirm,
I don't see the value proposition here, at all.
An SMSL AL400 (as a quick example) gives you so much more bang-for-the-buck... for $50 more.
I almost voted it the headless panther.:(
Did you yet test some of the newer than LDAC Bluetooth codeces?
Cheers!
I haven't been able to have both ends of it supported in anything I have had in hand. Which devices support them and what does Android/Samsung have in their phones?
It is identical to max power except that 40 Hz is used instead of 1 kHz. I don't remember if it is 1% distortion or 0.1%. Will have to check.
The power vs distortion has rough accuracy as I can't keep the amp at full power while I step the input in small amounts. I have made it better in recent tests but still not as accurate doing a max/burst power. Those tests also use a constant limit for distortion whereas the power sweep just notes the knee. That knee naturally varies between amplifiers.
$50 is a lot of money when the cost of the amp is $240! It buys a lot more hardware (as far as parts are concerned).
It's a unit that is perfectly suited for medium sized rooms where a small footprint is required or preferred. I currently use mine in the main bedroom where I like to have two available RCA inputs plus BT. The quality of the BT is good, I really don't notice much if any difference between it and the rooms where I have a Fosi S3 streamer.
As I mentioned in my writeup, I find the sound of the fan to be very faint. If you have younger ears, and are in a smaller room, this might not be your pick for a desktop amp. It bothers some people, though, and some have gone so far as to modify the fan or unplug it.
Tone controls come in handy from time to time.
In terms of price, it felt just slightly high to me, but probably because Fosi has released some good products with very low price points.
Nice to see it is measuring well!
My little bedroom rig with the Fosi…
Would like it around $180. Perhaps it would go down to $200 when on sale. For the current price, I would like to see an all-in-one box (a decent dac/amp).
Great review as always. Really impressive to see noise and distortion figures this low at $240, especially with a motorized volume control packed in.
What is the point of the AL400's subwoofer output when it has no switchable HPF? Without a crossover, the main speakers will typically be producing distorted bass at the same time as the subwoofer is playing clean bass.
I do appreciate all the extra inputs on the AL400. But for anyone who intends to pair their main speakers with a subwoofer and whose primary source is LDAC from their phone (or computer) then they would be far better off with the FOSI BT20A MAX. Then they will always be able to add a cheap DAC if they need the extra inputs in the future.
Which subwoofer plays clean bass?
As we see over and over, they are probably focused on extension and output, not distortion, they are not particularly good there.
As to the amp, I voted fine for the motorized pot alone, despite the uneven FR and loss of power down low :)
Thanks Amir!
This doesn't seem to have a HP Crossover, only LP? In this class I would prefer the HP.
YES HPF for Mains pair is what is missing from 97% of amps claiming 2.1 support.
Mostly an AV gear thing, or roll your own crossovers.
But xover point should be variable, ideally continuously so
There is what looks like a fan control on the remote. Does that mean you can switch it off, or is it always triggered by temperature, or?
Hi-fi is now inexpensive. Yet another clear example of that. Max Headroom (remember him?) may have a few issues with this amp, but I do not.
