Fosi BT20A Max Amplifier Review
Rate this amplifier:
    Votes: 2 1.3%
    Votes: 33 20.8%
    Votes: 107 67.3%
    Votes: 17 10.7%
This is a review and detailed measurements of the Fosi BT20A MAX stereo amplifier. It was sent to me by the company and costs US $240 with included 48 Volt/5 Amp power supply.
This is the beefiest cast I have seen in this compact, desktop amplifier category. The chiseled out MAX logo exposes orange grill that gives it a manly look -- kind of like a hood scoop on a turbocharged car! I was very surprised to read that the volume control is motorized. This used to be a premium feature reserved for many expensive audio products.
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp remote control back panel review.jpg
While I did not test it, the Bluetooth input supports LDAC which is the only transparent wireless DAC I have tested.
Dual RCA inputs are included which is an unusual touch, making the unit an "integrated" amplifier rather than just a power amp. Inclusion of trigger input for automatic power on with your source is appreciated.
There are of course tone controls. I tested the unit however in its bypass mode. There is also high pass for the mains output which is appreciated (again, I did not test).
Fosi BT20A Max Amplifier Measurements
As usual, we start with our dashboard of 1 kHz into 4 ohm load at 5 watts:
Those are extremely good noise+distortion figures. I think this is the best Fosi has produced, placing it well above average of all amplifiers tested regardless of price:
Zooming in:
The amp uses PFFB which reduces load dependency and improves linearity:
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp frequency response Measurements.png
As is rather typical, that control essentially only exists in audible band after which, output impedance still increases resulting in that resonant peak around 40 kHz.
Frequency response elsewhere harmlessly deviates from flat - more of a bother for the eye than anything for the ear.
Noise performance is excellent, almost achieving 16 bit dynamic range at just 5 watts:
Channel separation was especially good:
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp channel separation Measurements.png
Typical of most amplifiers, distortion rises with frequency but here, I think it is a bit more than I remember for the class:
Which then gets even more exaggerated with 19+20 kHz tones:
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp 19 20 kHz intermoduation distortion Measurements.png
Power specs are of course highly exaggerated as it is for the entire class. But this is a powerful little amp:
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp Power 4 ohm Measurements.png
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp max and peak Power 4 ohm Measurements.png
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp Power 8 ohm Measurements.png
While it derates some at 40 Hz, it is unlikely you need it there:
As noted there is increasing non-linearity at higher frequencies:
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp Power 4 ohm vs frequency Measurements.png
Amp is stable on power up:
Is quiet on power up but will likely make a pop on power off:
Fosi Audio BT20A MAX Bluetooth Stereo Power Amp Power on off noise Measurements.png
The power switch is shared with input selector so some of that messiness may be due to it first switching inputs and then powering off.
The BT20A MAX -- the third iteration in the naming -- makes a strong showing at the start with very low noise and distortion for its class. The former is competitive even outside its class. The inclusion of tone controls while appreciated, may be responsible for tiny variation in frequency response. Clearly the design is highly optimized to reduce impairments that can easily creep in this category of amplification. Feature set is quite nice and impressive seeing how we have a motorized remotely controlled volume, making it suitable outside of desktop use.
I am going to recommend the Fosi BT20A Max amplifier.
Is the fan inside of it audible?
Nice...I have Gen 1 and it's been chugging along for a while now.
Headphone in?
Out, of course. Sometimes I'm sitting on my brain (after a cerebral bleeding a few years ago), sorry.
But ad rem: I see more and more affordable amps losing the headphones option.
I am not big on having a headphone jack on a power amp. If it is in the main system, then it is not useful to have it there as it is too far from where one sits. If it is on a desktop, then they tend to not be nearly as performant as a dedicated headphone amplifier which I actually like to see combined with the DAC, not the power amp.
Oh :facepalm:
I thought it's an integrated (since it has bass/treble and sub out).
Reactions: EJ3
Nice, glad it performs so well.
So many power amps these days have SOME preamp functions
source switching, level control
Does NOT mean it has enough to actually call it integrated IMHO
but many do...
bass management is another "extra" and very welcome whether DSP or analog.
Personally I want continuously variable ideally both on the sub(s) and main with a rumble filter so 15Hz up to 200Hz.
Really I want Stereo subs (2x4)
But all that could be separate at line level, built into the amp is a lot to ask.
Thank you for the review.
I appreciate the added conveniences of a 2nd analog input, an 80Hz High Pass Filter switch, and a trigger input in a performant implementation.
Did you yet test some of the newer than LDAC Bluetooth codeces?
Cheers!
