The ZP3 arrived today. Quite a bit lighter in weight than I thought it would be. Build quality is typical of recent Fosi gear, good.
So I set it up, popped in the XLR’s, rigging my iFi Zne One Studio which is being fed, hardwired with the new Fiio Link Cable, my iPad A16.
First impressions in all honesty, a little on the drier side of sound. Not quite as resolute as the P4 from Fosi. That said, utterly usable and good to have as a preamp for my rig.
So here goes my warranty possibly but an hour after arrival I decided to pop the hood in the ZP3 and replace the NE5532 op amps.
Getting those glossy sheet plastic panels is easily enough with a good heat gun and flat spud/small spatula and a bit of patience. I unscrewed all the external screws apart for the 4 tiny star nuts holing the small PCB board next to the power supply. Those screws just would not budge! I let them be and worked around it.
It meant I could not remove the board from inside the unit. Instead after removing the side panels used a long pick to prize out the two op amps, it was tricky but they popped out eventually.
I replaced them both with a pair of custom made opa828 dual op amps and reassembled the unit.
After putting the unit back into the rack and hooking everything back up the moment of truth was upon me. I nervously turned the power on making sure everything was turned down first. Power on was fine, relay switch kicked in, fine. I then began to increase the volume and……yes, better!
A huge increase in ‘air’, vocals, organically speaking, sprang to as close to life as I could understand without a physical invitation to the singer himself. Bass, clean and tight life just poured into the soundstage and the center image became rock solid. This was and is a huge improvement and it was worth the effort.
So even with the lack of info on volume which in truth I use my ears for and have good practice of turning thing down before on and the apparent distortion of the tone controls which I never used on the P4 much either and so the machine remains in bypass I have to say this is very much not a weak link in my chain and has brought a great deal of soul to the sound which is not a bad thing at all.
View attachment 537066View attachment 537067View attachment 537068
