somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 6,750
- Likes
- 6,655
Welcome @OC6Huki - since you seem to be using balanced interconnects all round, one or more of the components is probably not following AES48 and has a 'Pin 1 Problem'. There's a good chance it's the ZP3 but it could be one or more of the others in a way that doesn't cause a problem in that combination. You can find out for sure which component(s) aren't following standard using the method in Jensen Transformers' Application Note AN007 sections 3.3 and 3.4 if you can do a bit of DIY. If the Outlaw has a ground lift switch then you could try that - the ZP3 doesn't. Another option would be to try a cable with the shield disconnected from pin 1 at the receiving end - see AN007 section 3.6 for why it's the receiving end not the source end. Failing that, see the transformer isolation proposed in AN007 section 3.5.
