Fosi Audio ZP3 Preamplifier Review
Rate this preamp:
    Votes: 38 16.4%
    Votes: 60 25.9%
    Votes: 102 44.0%
    Votes: 32 13.8%
This is a review and detailed measurements of the Fosi ZP3 balanced preamplifier. It was sent to me by the company and costs US $189 (coupons available for less).
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone crossover review.jpg
Despite its low cost, the look of the unit is attractive to me. As is the functionality of having balance and tone controls. What is not is the volume control. It is a rotary, microprocessor controlled volume control which nicely allows remote control access (supplied). The problem is that there are no indications anywhere was to what you have set the volume to. You can easily turn on the unit with volume set to max and cause panic. Usually rotary controls have some kind of display or at least bar graph showing you level. Mechanical ones don't have this issue because they have minimum and maximum stops which we don't have here.
But there is plenty of good news in the back:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone crossover back panel review.jpg
Despite the low cost, we have XLR (combo) balanced input in addition to dual RCA inputs. What's more, a couple of switches underneath let you invoke a high pass filter for main outputs, allowing the system to properly integrate with a subwoofer. I will show the response later. Trigger input is there as well in addition to built-in power supply. Let's see how it performs.
Fosi ZP3 Preamp Measurements
I started with balanced in and out, feeding the unit 4 volts:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone control bypass measurement.png
I like to test amps in "unity gain" meaning same voltage out as what is put in. Alas, I could not do that here as the volume control digital steps are rather coarse, jumping from 3.8 volt to 4.4. I decided to give it the benefit of doubt and going with the latter. SINAD of 108 dB is excellent for a such a pre-amp, leaving plenty of headroom to play 16 bit content without much disturbance. As you can see, third harmonic sets the SINAD. Noise itself is quite a bit lower which is nice:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone control bypass SNR measurement.png
Switching tone control takes its toll though:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone 80 Hz High Pass SNR measurement.png
Unbalanced in/out shows fair bit of degradation over balanced due to added distortion:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone control bypass RCA measurement.png
Here are your choices for frequency response:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone control bypass frequency response mea...png
Note that if you enable tone controls but leave the switch at "20 to 20 kHz," you get some additional low frequency roll off. So I suggest selecting "bypass" if you don't want filtering.
Crosstalk is excellent for a product at any price level let alone what we have:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone control bypass crosstalk measurement.png
IMD response shows that higher performance (and more expensive) amps don't have to close shop, especially if you enable tone control:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone IMD Distortion measurement.png
We can see the same in our wideband distortion vs frequency test:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone distortion vs frequency measurement.png
The preamp can produce lots of output voltage which is nice though optimal level is what I have tested:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone Distortion vs Level measurement.png
This though, aggravates the issue with lack of volume level display as you could seriously overdrive your power amp and speakers. On the positive front, if your power amplifier is low gain, you can take advantage of that with better SNR by using the pre-amp to push it at higher voltages.
Recently, we have had a lot of discussions around "phase" measurements. I thought I give those people a nod by showing the phase response with and without tone control:
Fosi ZP3 balanced RCA subwoofer preamplifier preamp tone crossover phase measurement.png
When integrating with a sub, this phase shift will interact with sub's own phase response, producing likely unexpected total output. This, then gets manipulated with room modes. Translation: you better measure your room and deal with it that way than try to compute/predict your way out of it using this kind of measurement.
Fosi continues to push the price/performance metric ZP3. It is feature rich and includes many things members ask for. But as they say, be careful what you ask for. Analog filtering of the output has a real cost. Lack of volume control indicator is a serious usability issue for me personally. For that reason, I can't recommend the ZP3. If that doesn't matter to you, and you are on a budget, the ZP3 can make for an excellent preamplifier.
It's a darn shame the volume control/display issue was not better thought out on this one. I agree that it's not a small problem.
I don't remember the tone controls causing as much degradation as here on the recent Fosi P4 RCA-only preamp - am I remembering correctly?
Thanks Amirm - you've really been cranking them out lately. I particularly appreciate amplification over source components or speakers, nothing like horsepower! Or in preamps case, transparency. Between your measurements and price I've gone with ADI2 Pro (set to +24dBu) > Benchmark HA4 > Benchmark AHB2s x2 set for mono into a pair of Tannoy Saturn S10s, plus a second chain feeding a pair of Genelec studio monitors and sub. I can easily hear the difference between CD and Hi-Res. GOD we live in great times for audio! Thanks much for all the recommends.
Pic not related
Nice review of a decent unit - and bonus points for so clearly demonstrating and explaining why phase measurements are of limited use here.
ALOT TO LIKE....i am a little dim...so is it having the tone controls that cause the problem or is there a bypass setting that is an issue?
with regard to the volume control ...we have eliminated many of the pops, hiss and crackles with class d and such Maybe we need a little risk to remind us how far we have come. LOL
Probably you do, but all tests were a bit different. @amirm was in testing the P4 more interested in flipping through the three gain settings, than comparing tone control on/off - if you look at the degradation in frequency response, you can see that the P4 has 1dB degradation at 80 kHz with tone control on. The ZP3 only 0.5dB.
The over all flatness is better at the P4 which doesn’t have the 0.6dB loss at 20 Hz:
If really there is no way to tell the volume than it's an absurd fault that cannot be passed, no matter how good performance are.
Poor for me.
Thank you as always for the review!
Agreed
Fosi Audio could offer another (optional) volume control knob for the ZP3 fashioned to look like an American 'STOP' road sign. ;)
Thank you for the review, @amirm,
...When integrating with a sub, this phase shift will interact with sub's own phase response, producing likely unexpected total output. This, then gets manipulated with room modes. Translation: you better measure your room and deal with it that way than try to compute/predict your way out of it using this kind of measurement...
This is very valuable.
??? But you can see the Volume setting immediately by just watching at the orange Volume Knob!
Just in case you are serious :), that indicator means nothing. The knob will rotate and rotate infinitely.
