Fosi Audio ZD3 Balanced DAC Review
Rate this DAC:
    Votes: 5 1.5%
    Votes: 7 2.1%
    Votes: 81 24.0%
    Votes: 244 72.4%
Thanks for the review Amir.
DACs certainly are a solved problem and this is an excellent example, however, I see no benefit in replacing my Benchmark DAC2, SMSL SU8 or Topping D50s. These all perform extremely well in their respective systems and the only reason to upgrade would be for a DAC that included EQ and DSP filters.
Why do EQ and DSP filters MATTER that much? How does it work in the audio listening?
Ask in this thread;
JSmith
Thanks for your kindness
the fact this is as low as $130 on ebay with11/11 sales and coupons makes it a no brainer
i do get there's some issues with the hdmi and the BT is truly 5yrs behind the times but as yet no one comes close with the price
and fosi at least update the firmware
What kind of issues like on the hdmi and the BT?
But V3 mono is an amp, but this one is a DAC and preamp
V3 mono is a power amplifier. This is a dac with preamp function. What's the problem?
It's made to work together.
I really don't know what's your point.
Why does HDMI matters that much for a DAC
Well it is a benefit to be able to send stereo PCM from a TV via HDMI ARC. This avoids any signal lock-on issues with optical, or any need to adjust DPLL settings (if available).
JSmith
And if you are using the DAC into an amp or active speakers, HDMI CEC lets you use the DAC like a soundbar where the TV remote powers on and off the audio system and also allows volume control.
Why do you think a analog input would be better?
People want an integrated pre-amp in a small form factor. Optical, Coax, USB, Bluetooth, Hdmi and analog inputs. Swiss army knife.
We need basic smoke testing of the HDMI, not just from an audio quality perspective but to confirm its basic functionality with the TV.
Many of these devices have bugs in these simple features.
The following three questions should serve as a checklist:
- Does the device turn on and off automatically?
- Can the volume be adjusted (CEC)?
- Are there any noticeable sound issues?
What is smoke testing? Why do you think it is necessary for HDMI?
Amir calls it "desktop" but with those inputs, features, and remote it would work well also in the living room and TV room.
Fosi Audio should make something similar but with EQ for room correction and preference.
Why do you think a dac with EQ for room correction and preference is vital? How many modes is worthwhile?
Hi, On paper, how would this compare with an Eversolo Z8?
Exactly my questions and there's no user manual available at this time at https://fosiaudio.com/pages/user-instruction.
In addition: Will the device switch automatically to HDMI input when a TV is turned on? Are volume levels remembered separately for each input?
The holy grail: balanced output, signal sensing for source switching, signal sensing for on/standby, separate "last volume" memory for each source, trigger in/out, HDMI with CEC where the TV remote does everything.
Many reasonably priced devices with all but one or two of those. I just want a good, flexible two channel system, not a big AVR box, where I can control music and control TV with a single remote for each. Essential in a multi-user household where other people won't grasp all the particular interactions of connected devices. The increasing prevalence of Bluetooth remote controls makes it that much harder to integrate devices for remote control.
Why a remote control for integrate devices is important? And why do you attach importance to the volume remembering? And what is a two channel system?
It's not essential because these can be implemented elsewhere. But many of us listen in rooms that dominate the bass and should be corrected for and we all have our preferences and some recordings need correction too.
