OdiusEX
- Joined
- Nov 1, 2024
- Messages
- 10
- Likes
- 8
How many steps is that? 30? And in Italian.Fosi Audio ZD3 \ DAC Sabre \ Bluetooth 5.0 \ HDMI ARC \ Unboxing
How do you use the ZD3 with an LG TV on HDMI ARC? I'm not getting any output from the ZD3. On optical it works perfectly.
I turned off the CEC functionality to avoid that power on bug, but it shouldn't be related to the audio part, or is it? Do you use eARC? What settings do you put on the TV exactly? I have a LG G2.
The linear regulated power supply ( lower left ) is a nice upgrade in SQ for the ZD3.
It's an Astron which isn't cheap but I've also had good results with much less expensive linear power supplies from Pyramid.What linear psu is that? Link?
One of these is needed for a connection to the Fosi DAC.
The connector is marked + and - and as long as you observe polarity you're good to go.Thanks, appreciate the info!
My Nikon z6 was purchased in 2018 and its oled top display is just fine. Same with the z8 which is a couple years old now.OLED is the incorrect choice for a static display. I will likely be unreadable within 6 months.
Martin
Fosi say they have a fix, but the ZD3 needs to be replaced. I've sent mine to where I purchased from.Has anybody been able to resolve the power on bug with a LG Tv?
Thanks, so it’s a hardware fix!Fosi say they have a fix, but the ZD3 needs to be replaced. I've sent mine to where I purchased from.thanks
They said software, but cannot be done remotely.Thanks, so it’s a hardware fix!
I don't have my ZD3 connected to my LG B4 but I have had many issues with HDMI CEC via my Denon, Apple TV, and PS5. More so with the Apple TV. On my Sony and Samsung tvs, no issues whatsoever. Searching online - tons of user reported issues with LG's handling of HDMI CEC.Found this on the LG site if it helps (http://kr.eguide.lgappstv.com/manual/w23_mr3/global/Apps/w23_mr3_us05/u_enga/settings.html#)
Using eARC Supported Audio Device
Sound Advanced Settings eARC Support![]()
eARC is a technology that can send and receive more sound information faster thanks to its wider bandwidth than that of the conventional ARC. You can enjoy TV sound with higher quality than ARC through a connected audio device.
- Connect an audio device that supports eARC to the HDMI (eARC/ARC) port.
- Go to Sound Out Use Wired Speaker and choose HDMI(ARC) Device.
- Set eARC Support to On.
Mine just arrived and my initial impression is very positive. Sounds perfect, looks great, feels great, and the HDMI/CEC works perfect right out of the box. LOVE it! Thank you @Fosi Audio! You guys are really bringing your "A" game lately and I appreciate it immensely.
