Fosi Audio ZD3 $179 and Presale starts Sept 19
I want a (hot) swappable DAC chip... now that would be a nice feature. :)
Thanks for confirming. Think I might have to spring for the WiiM Ultra and add it to the mix.
The package sent by Fosi Audio took 10 days to leave Shenzen and arrive at home in France. This time, Fosi has evolved in the packaging and offers us a nice package, worthy of the big electronics brands. When opening, the feeling is the same: we feel a quality product, well packaged with the accessories provided. The presence of a minijack/minijack cable to turn on the ZA3 is a plus (Trigger 12v input and output).
The power supply provided is a traditional 12v, ensuring a stable current for the ZD3. The remote control is light and seems low-end but sufficient for its use (be careful, the two batteries are not provided).
The ZD3 is built with the same quality as the ZA3: black anodized aluminum chassis, orange aluminum volume button, rubber feet, impeccable printed circuit and exemplary assembly, we feel that the assembly line is not at its first attempt.
Disassembly for a possible change of the OPAmps chips is easy with the two screws on the back and the volume button to remove, as on the ZA3. Be careful not to tear off the "bypass" connector during this operation!
The connection to the ZA3 amp is made by choice in XLR (5v) or RCA (2.5v) even if this has little impact on listening on short cable lengths. A discreet but present Bluetooth antenna ensures compatibility with the APTX HD codec on my Samsung A52s.
On this side, the sound is powerful, clear and I can't hear any difference to the ear with the same song played from my Android box on the Optical input of the ZD3, it's a good point. The Bluetooth range is respectable, at 5m through light walls of my apartment, the sound plays without interruption.
Listening
I spent two years with my Topping e30 Pro II DAC which remains a quality reference in DACs around €150 and I was very happy with the clear musical result of the two AK4493S chips. The ZD3 tempted me for three main things: Bluetooth (for evenings with friends or to quickly take music to someone's house), XLR outputs (to theoretically optimize the connection to the ZA3) and of course the design, perfectly adapted to the ZA3 for a homogeneous ensemble in my living room.
Once connected to my source in Optical or HDMI Arc to my TV (practical to manage the volume of the DAC with the remote control of your TV), I turned the volume of the ZA3 up to full, and then it was off for a listening experience totally comparable to my Topping E30 Pro II, clean, clinical, detailed, without coloration. Note that the maximum volume of the ZD3 is 80 and not 100.
I didn't find any hiss or background noise even with my 93.5db sensitive speakers.
Using the ZD3 as a preamp and DAC, I have therefore not tested the "bypass" function located under the case.
Through the ZA3 I played music through the ZD3 on my two pairs of fairly similar French speakers: Focal JmLab Profil77 (1996) and JmLab Opium 603 (1988), both pairs renovated with Mundorf MKP capacitors. The titanium (Profil 77) and kevlar (Opium 603) tweeters can be tiring with poor amplification. Here, it is not the case with the ZD3 + ZA3 combo even at high volume where the kevlar tweeter tires faster than the titanium tweeter.
Clear sound on every inputs
Flawless design and good color screen
Improvements ?
For around 200 euros, you can find a lot of decent DACs from the competition but very few with a useful HDMI Arc input even if not essential. On the other hand, if you like the design, it is certainly the one that stands out the most and takes its place in a living room. My wife finds it pretty at home and that is the main thing!
I would nevertheless like to make some improvements that I find important for a future version:
Support for the LDAC codec for even better Bluetooth
The 12v power cable is too short, one more meter would have been perfect
A USB type C input to connect to smartphones without having to find an oldschool adapter
An Android/Os application with equalization management
I didn't find the online manual to be able to safely open the case
Recommandation
I highly recommend the ZD3 with its original LME 49720 chips that have their place in high-end audio equipment.
Easy to use, responsive and well finished, it is the ideal companion for a Fosi ZA3 or a pair of V3 monoblocs.
In France, you can buy it on Audiophonics.fr if you need to be safe with a local seller or on Amazon.fr at the best price.
If you want to listen it live, you are welcome at my home for a free listening session in Besançon, France.
So one gets 3 LME49720's in the device, then they encourage people to swap them out? All this does is make the user wonder if they have used the optimal op-amp... I wish they would stop encouraging this, as one doesn't customise sound by swapping op-amps;
JSmith
But what are you trying to say? Everyone has their own taste. One prefers OPA1612, the second MUSES02 and the third a double OPA627 configuration. I used LME49720 in SMLS SU-1, but I replaced it by soldering OPA627.
