solderdude
Treble response above 10kHz is load dependent (the A800 is not and always peaks a 0.5dB @ 20kHz).
So depending on the impedance of the used speaker the upper treble (sharpness/air) can vary in level depending on the speaker.
When it is used for an active speaker (high section) it may be best to ensure the tweeter load impedance is around 4ohm frequencies > 5kHz.
Unless ... you want the treble peaking (to get more sharpness/air) then you could increase the tweeter impedance to get some extra upper treble.
The ZA3 with 4ohm tweeter load thus will sound less 'sharp' (1dB difference at 20kHz) than A800 and similar at 8ohm load.
