Fosi Audio V3 op-amp rolling, has anyone tried it? Snake oil? Or are there actual differences?
The potential complication for A/B tests in audio is that, just as there can be nonreportable differences in what we see even though our behavior demonstrates that somehow unconsciously we're still seeing, and acting accordingly, there may possibly be nonreportable difference in what we hear, which in A/B tests we cannot report, but which nonetheless have significant effects on our behavior -- where in this case behavior includes level of enjoyment of music. Given the far-from-complete theories about why music even works, that some of the work may be significantly by communication across unconscious channels can't be safely discounted.
I agree. This is a common occurrence when, when comparing devices, there seems to be no difference. But after 1-2 weeks you feel something wrong, and sometimes even after 1 day.
Exactly what I did with a little Aiyima, which allowed OPamp rolling on both its I/V and LPF functions. I tested several combinations, running 44 measurements per channel each time (THD, THD+N, IMD, bandwidth, phase, jitter, SNR, linearity, crosstalk, etc…). A Motu Ultralite Mk5 was used as the capturing device to perform measurements with REW.
A friend of mine did the same exercice using an old Yamaha CDX-390 CD player and using a Focusrite for measurements.
Great work!
But I believe that with equally good measurement results, the sound may differ.
Real music is structured completely differently than test signals: these are chaotic bursts, beats, the simultaneous sound of hundreds of harmonics and sharp transitions from silence to explosion.
Psychoacoustics also cannot be ruled out. If the listener is confident that he has good components, he can enjoy the music more, rather than look for flaws)
Great work!
That we measure too, and to an extend music will never reach. But you’re of course free to believe otherwise.
I also organized blind tests for these and none made a difference to the listeners. Only the one that was generating 0.4% THD got identified, but again, it’s because it was as badly inserted in the socket :)
What speakers or headphones did you listen on? Have you used planar monitor headphones with a powerful high-quality amplifier?
Great work!
In general, measurement instruments are at least an order of magnitude better than human hearing in all relvevant metrics. If you can hear a difference, you can always measure it. This idea about test signals is also a common misconception. Apart from the fact that there are others like multitone which, when shown in the time domain, are indistinguishable from real music, there is no inherent problem with using clean and simple test signals.
True. This is commonly attributed to bias. But that's the classic case where the devices would measure identical and actually perform identical, yet the listener would still claim to hear a difference. But the next day, he may not hear it anymore. And then, a week later, his impression may change angain. All that, while his system would still perform identical to day one.
So clearly, subjective impressions from sighted tests are not reliable, do not correlate with actual sound quality and should not be used to judge the performance of an audio setup.
