There is measurements on plenty of sites on Hegel h390. Hifinews ex, the Fosi measurements is peak power which is short term.
Those 240 watts into 4 ohms is peak power and they can’t put out that consistantly, its closer to 170-180 watt rms into 4 ohms.
If you are still referring to the V3 mono, please at least take a quick look of post#4962 by Talisman:
https://www.audiosciencereview.com/...-amplifier-review.53474/page-249#post-2662652 that linked to the power output measurement graphs.
and also the ones below from Amir's tests/measurements:
The 243.6 W is not "peak" power, it is just power output at 1% THD+N.
The 241.8 W, that is basically the same, the little difference is within the margin of errors that one can expect from different sweeps/tests at different times. The term "Peak Power" Amir used was technically not correct, though people often loosely use that term, to be more technically correct, it is just "Power", or average power, and is directly comparable to the H390's measured 490 W, also into 4 ohms and at 1% THD+N. Keep in mind when comparing such results based on different test benches/operators, it is important to try and do it in the so called apples to apples way, in this case, since Hifi news used 1% THD+N, we should also pick the number from Amir's based on 1% THD+N.
Edit: I should also mention that the CEA-2006/490A is the standard that Amir uses to measure Dynamic Power, so again, not peak power. Many on ASR would know that for peak power = 2X average power. Also note that as Amir has pointed out more than once before, such class D amps often have little to no headroom. It is not always a bad thing, it depends on the reason behind. Amp manufacturers, such as Anthem, had mentioned that low headroom can actually be a good sign.
So, based on actual bench test results, it should be easy to agree that the H390 can be pushed to output 3 dB more into 4 ohms at clipping, vs the V3 mono. I don't think anyone would disagree with that anyway. Hopefully we all see no need/no point to debate this particular point any further.
By the way, I would like to take the opportunity to repeat the point that on such forums (though ASR does better for sure), I wish we can try and contribute to slowly but gradually improve on not mixing the terms "continuous" power, "peak power", and just power, or average power and stop using the term RMS power, though I would agree it isn't a big deal regardless, other than it is better to do it right especially on ASR, that I assume pick the name with "science" in it for a reason.
